avatar_Wardukw
Ukrainian AV-8B Harrier.
Started by Wardukw, October 31, 2023, 09:32:52 AM
The title pretty much says it all ...it will be built almost OTB ..I'll detail the cockpit as it's in dire need of it .
Since im picking up another Harrier today which is a GR5 and there's gonna be another AV-8B in the mail today I'm gonna wait and see which is the best of the 3 ...one is the good but extremely old Monogram AV-8B and the other 2 are both Hasegawa.
Looking for Ukrainian air force decals and they can be found but mostly from the US so stupid postage prices.
Plenty of camo mask sets but I don't need em ..I'll do my own ..im looking for decals for Ukrainian aircraft only ..not mixed but I guess it's a start..Hannets have mixed sets which I might have to look at as long as postage is reasonable.
Quote from: Wardukw on October 31, 2023, 09:49:19 AMLooking for Ukrainian air force decals and they can be found but mostly from the US so stupid postage prices.
Watch out for Begemot sheets - there are several (vast!) 1:72 sheets that contain Ukrainian markings, some in multiple variants. The print quality is also very good.
Quote from: Dizzyfugu on November 01, 2023, 03:39:55 AM
I need 48th scale ones Thomas mate..ive seen the amount of 72nd and vast works there too...48th is a not so much one which is annoying 🙄
Could you use a couple of circle templates and spray the yellow and blue?
Quote from: kerick on November 01, 2023, 04:54:24 PMCould you use a couple of circle templates and spray the yellow and blue?
That's definitely on the cards mate ..the annoying thing is the other markings..there's this sheld which seems to be on all Ukrainian aircraft .
That's the PITA part.
Quote from: Wardukw on November 01, 2023, 10:41:07 AM
IIRC, Begemot also has some 1:48 stuff, but I am not too fmailiar with that product line.
Quote from: NARSES2 on November 02, 2023, 01:48:06 AMHannants have no dedicated sheets but do have these in 1/48, so you might find them nearer to home ?
https://www.hannants.co.uk/product/BT48028?result-token=HWtsR
https://www.hannants.co.uk/product/HD48015?result-token=HWtsR
Those sets are pretty much perfect Chris  ;D
The first set is the one I'll probably get ..it's got a ton of decals in the set..worth the $19 nz for that set..haven't looked at postage yet so hopefully that ain't a stupid price.
Quote from: Dizzyfugu on November 02, 2023, 12:17:55 AM
I took a look at the Begemot decals and yep they look nice..the price tho..freaking scary mate..from one seller it would eork our at over $40nz ..that's abit much  :o
Quote from: Wardukw on November 02, 2023, 07:47:01 PMI took a look at the Begemot decals and yep they look nice..the price tho..freaking scary mate..from one seller it would eork our at over $40nz ..that's abit much  :o
Yeah, postage to NZ will probably "kill" anything.  :-\
Quote from: Dizzyfugu on November 03, 2023, 01:20:07 AM
Not just that bud ..the price in general..€19 here $20US there ..€19 is like $35nz and funnily so is $20US ..strange that ..that's pretty much what I payed for one of my Harriers .
The links Chris gave I think are gonna bare more fruit ..the prices at Hannants are like £8 but when I can afford em then I check the price.
Postage of sheets of transfers from Hannants to 'straya isn't too bad as they can send them as letters.  Should also be the case if sent to Un Zud.
Quote from: zenrat on November 03, 2023, 02:17:30 AMPostage of sheets of transfers from Hannants to 'straya isn't too bad as they can send them as letters.  Should also be the case if sent to Un Zud.
That's exactly what I'm hoping for..it's a sheet of paper so postage shouldn't me to bad  ;D
#14
Just made a order with Hannets for a set of Begemot Ukrainian decals .
Thanks to Chris and Thomas for that  ;D
Once I've got those I'm really going to attack this thing .
I was looking at getting  a masking setcfor the camo but that was alittle to much so I'll do it like I normally do 😊
