avatar_zenrat
SEPECAT BNP-B1 SuperJag. Finished pics pg 8.
Started by zenrat, November 05, 2023, 02:15:38 AM
Final legs by the looks of it.. nice work
Quote from: kerick on November 28, 2023, 08:08:38 PMAmazing!
BTW, one of the guys from the reserves squadron I was in did the same thing with the web of his hand but with an air nailer.  :o  :angry:
Guy at the UPVC window frame manufacturer where I used to work did it with an air drill and a self-drilling screw. Securely fastened himself to 2 metres of steel-reinforced patio door frame for a few seconds before he stopped shaking long enough to find the switch and reverse it out.
He walked round the factory showing everybody, with a manic grin on his face, for about ten minutes after that while the old salts waited knowingly, then the adrenalin wore off, he took another look at it, actually thought about it, started shaking again, and promptly passed out.
Quote from: zenrat on January 13, 2024, 01:46:28 AMSEPECAT BNP SuperJag WIP 13-01-2024 by Fred Maillardet, on Flickr
I had a rummage through a weapons box today and dug out a Red Beard (Airfix TSR2) to hang under this thing.
Looking good!  :thumbsup:
Mind you, that thing's fineness ratio is so short that it's sonic boom would probably qualify as a weapon of mass destruction at low level.
Phat Cat?
Main gear legs (Mitsubishi T2) glued on today.  Also detail painting on UC bays, coaming, metal bit under the tail etc.
Showing your age, or lack of it, with Bagpuss  :angel:  ;)
 "a saggy, old cloth cat, baggy, and a bit loose at the seams"
I identify with that description.  Well, not the cat part, but the rest.
Done apart from the load out.  And I put the first layer of colour on that today.
SEPECAT BNP SuperJag WIP 07-02-2024 by Fred Maillardet, on Flickr
The Fat Cat looks very good, even while being a bit "thick" around the waist line...  :wacko:  ;)  :thumbsup:  :thumbsup:
Just one thing that's looking a bit off to my eyes, isn't that canopy sitting too vertical?
Possibly.  It is supported by a tongue sticking in a hole so it is removable.  I can bend it.
