avatar_zenrat
BAE Harrier GR7A JASDF Maritime Strike, Finished pics pg 5.
Started by zenrat, November 21, 2023, 03:00:07 AM
perttime
Thread title has somethijg about "blue"...
Quote from: perttime on December 02, 2023, 11:56:10 AMThread title has somethijg about "blue"...
I can't stand Donald Duck.
Cockpit attached to fuselage today.  While doing so I got inspiration for a Tophe build... ;)
PSR (minimal) finished today and I put a coat of primer onto it
Am I correct in thinking that when on the ground Harriers had their UC doors closed unless ground crew had to stick their heads inside for some reason?
The mainwheel doors, yes, the nosewheel doors stayed open.
Thanks Kit.   :thumbsup:
Primer has revealed a seam on the spine which needs attention.
Which is annoying.
 :banghead:
I have begun smearing colour across her surfaces with a hairy stick.
Blue Harrier WIP 31-12-2023 by Fred Maillardet, on Flickr
Hataka Acrylic paint.  First time I have used these.  They dry very fast.
Quote from: zenrat on December 23, 2023, 05:26:20 AMPSR (minimal) finished today and I put a coat of primer onto it
If the engine is running then yes. I looked at quite a few pictures which supported this, only thing was that you could not see the main gear doors.
Quote from: zenrat on December 31, 2023, 02:33:07 AMHataka Acrylic paint.  First time I have used these.  They dry very fast.
They do indeed. They are my "go to" range now.
Second colour started.  Both will need another coat but I am impatient and like to see if reality is going to match the picture in my head.
Blue Harrier WIP 01-01-2024 by Fred Maillardet, on Flickr
I like the Hataka paint but have found it needs more effort to clean out of the brush than Vallejo does.  Probly because of the quick drying.  I had to work Tamiya Acrylic Thinners into the bristles to de-clag their roots.  Vallejo acrylics just need a quick swizzle in my water jar followed by a wipe on a rag.
Hmm, that 's odd. I find the Hataka Blue Line paints clean out of my brushes very easily, two swishes in the water jar followed by one in the Tamiya Thinners jar does the job.
Love the colours Fred
Quote from: PR19_Kit on January 01, 2024, 03:19:07 AMHmm, that 's odd. I find the Hataka Blue Line paints clean out of my brushes very easily, two swishes in the water jar followed by one in the Tamiya Thinners jar does the job.
Same here, except it's Humbrol thinners. Mind you to be on the safe side after a painting session I tend to leave my brushes standing in a jar of "Brush Magic" for 20 minutes or so as well.
Better and better.............  :thumbsup:
great scheme... I like that
