The ULTIMATE in wing extension, the Ho 267! - DONE!
Started by PR19_Kit, December 02, 2023, 06:52:26 AM
Quote from: Rheged on March 10, 2024, 08:11:32 AMI don't think I'd like to be in charge of the ground staff trying to get it into a hanger......................................or do the wheels castor through 90 degrees and they push it in sideways?
This being the Horton's design, the brothers built a special trolley which the 267 taxies onto and which then swivels through 90 degrees and goes into the hangar sideways.
And no, I'm NOT going to build the trolley, I had enough of them with the one for the Martin Monterey!  :o
Quote from: PR19_Kit on March 10, 2024, 05:17:04 AM
Quote from: zenrat on March 10, 2024, 04:59:10 AMDo you think the wings are long enough?   ;)
Nice work Mr Spakko.   :thumbsup:   I might have added castors or skid plates to the wing tips but that's just me.  It's awesome.  You need to do some Dizz style pics of it :thumbsup:  soaring in front of thunderheads.
If they were even 10 mm longer they'd touch the ground!  :o
And wingtip skids might have been a good idea, yes. Hindsight being the world's only exact science of course.............
I'm not up to Dizzy's level of photoging these days, way back I might have done, but I like the idea anyway.
Should be fairly easy to add them, just some stretched sprue.
Charlie_c67
Ah the good old Horton Bumerang. Question is, did it come back? ;)
According to the back story it never even went.  ;D
Brilliant Kit 👏  ;D  ;D
I like a long wing span and this definitely falls into that category  :thumbsup:
Love it 😀  :wub:
loupgarou
A glorious build!  :thumbsup:
Must have played havoc with airport runways and structures. Everything razed for kilometeres to leave space for that wingspan....  ;D
Quote from: loupgarou on March 11, 2024, 02:05:53 PMA glorious build!  :thumbsup:
Another possible rule: If it isn't causing trouble somehow, and/or somewhere, and/or somewhen, it probably isn't a whiff.  ;D
Glenn Gilbertson
KiwiZac
Zac in NZ
https://linktr.ee/zacyates
I'm not keen on the swastikas, they look too much like the ones the US was applying post war to their captured stuff rather than your actual late war Luftwaffe.
They came in the kit, in two halves each mind you, and I don't have any others to hand. They're the very DEVIL to print too, having done a few before.
They'll have to do for now though.
I just don't like swastikas.  But where you've put them the jet exhaust will scorch them off post haste.
:o MAD but elegant looking thing... like it... :thumbsup:  :thumbsup:
Doug K
 Wow, amazing, you may see some U2 wing-droop?  ;)
