avatar_Sisko
B-26 Marauder
Started by Sisko, March 21, 2005, 01:22:14 PM
frank2056
The old Monogram Snap-tite 1/72 B-26 was great for whiffing - great fit (it had to be!) dirt cheap and just enough detail, with plenty of room for more.
It's probably long OOP, but the Airfix and RoG are still available, for $12 and $10 each.
I'd love to add a turboprop to one. And a T-tail! Or at least move the elevators up a bit.
Frank
My alternate future had the Invader not being produced so the Marader soldiered on in those roles, Night Intruder in Korea and later, Vietnam.  French use in Algeria, etc.
Just thought about using it as a Firebomber, hmmm... maybe I need 3 kits.
Archibald
The AdA actually used both B-26s... Marauders were used by the FAFL (free french) until 1945, then B-26 were used from 1950 to 1963 in Indochina and Algeria.
So had more Marauders been produced in greater numbers, maybe they could have stayed in service longer...
Geoff
How about a AdA B-26 gunship in Algeria alongside the F-47s?
Joe C-P
QuoteAllan,
Unfortunately, that ability came at a price.  The ship had a fairly high wing-loading for it's size and cause many accidents amongst new pilots.  Ended up being called 'the Wido Maker' for a while there until the Army Air Corps got their training system sorted.
Still a sweet looking bird tho, I remember doing Airfix's job way back when and I fell in love with it.  Now of course Hasegawa has a couple out that make it look dated too I guess.
Mav
Only the earliest models had that problem. The wings on later models were extended by 6 feet, which cured the wing-loading problem. Unfortunately the plane already had the reputation by then.
The earliest models also could carry a torpedo. If a pair of depth charges were mounted on the wings, it would make for a good naval patrol bomber, being able to attack both surface ships and submarines.
I built one as a kid as well, one of my earliest dioramas. It's long gone, now, sadly.  :(  I did a lot of work on the base, which was a grass-edged tarmac.
JoeP
Maybe a pure jet or jet assisted version - say they wanted something to counter the Ar-234 and so either added 2 jets under the wings similar to the way the Soviets created the Tu-12 from the Tu-2S:
If the early jets weren't powerful enough, you could up the number to 4  - two in a single pod, similar to the B-45:
Alternatively, they could have kept the piston engines but add a single jet in the tail (with intake ahead of the tail fin) instead of the gunner.  This could be used to give the aircraft a speed boost when required.
elmayerle
Greg's suggestion sets up another idea, a jet engine at the back end of each nacelle with an appropriate intake setup.
--Jane Wagner and Lily Tomlin
Maverick
Wasn't the A2J Savage setup like that?  Jets for speed boost?
Mav
Archibald
QuoteWasn't the A2J Savage setup like that?  Jets for speed boost?
Mav
Yes it was, and more interestingly there had been an Invader with the same mods... if the Savage and invader can do it, why not the Marauder ? Hmmm a
R-3350 + J-35 Marauder...  :wub:
famvburg
Mav
    ISTR only one jet engine.........
upnorth
Well, Triple 7 beat me to the water bomber suggestion.
How about a bird for photo recce?
Or even target tugging?
My Blogs:
Floats, FLOATs! It needs floats! USN float bomber!
Sometime ago, a good friend of mine who knew I liked aircraft gave me an original set of design & engineering pamphlets of the Marauder.  Each pamphlet covers a particular section of the design and the engineering that went into it.
I don't know how common these are but the ones I have are quite old but I think it was post war when they came out with it.  I think it was for teaching purposes.
Robert
Maverick
I know the USN flew the A-26 as a target tug, and ISTR that the B-26 was also used, but can't remember if it was a tug or not??
Mav
McGreig
QuoteI know the USN flew the A-26 as a target tug, and ISTR that the B-26 was also used, but can't remember if it was a tug or not??
You're right - the US Navy flew the B-26. It was designated JM-1 and was used as a target tug for training shore based anti-aircraft batteries. Some were finished in a bright overall yellow colour scheme.
