Land speed record Lighning
Started by loupgarou, January 08, 2024, 09:53:53 AM
Maybe the stock car guys can get so decals for you.
loupgarou
Quote from: kerick on January 18, 2024, 03:02:33 PMMaybe the stock car guys can get so decals for you.
I can print the decals myself. The problem is reducing the logos and keeping them readable. Have some car decals in 1/87, but am afraid not the right images.
I find that reducing the images in size, step by step, works a lot better than shrinking them to the final size in one go.
Not quite sure why that should work, but it does with my software, PSP V 4.0.
I am following along as I also planned a Lightning for the LSR build years ago that got no further than buying the kit and drawing up some ideas.
I was thinking of naming it the White Lightning but really want to do it in British Racing Green.  We shall see.
Quote from: PR19_Kit on January 18, 2024, 07:50:33 AM
Quote from: loupgarou on January 18, 2024, 02:02:13 AMIt it were a german contender, I could have added, for ex., a Beate Uhse logo, but I don't know an analog british chain.  :rolleyes:
Having read up on Beate Uhse, I'd say your nearest equivalent would be 'Ann Summers' or 'Honour'.  ;D  ;)
Mate of mine's mate is the Ann Summers warehouse manager  :rolleyes:  :angel:
Quote from: NARSES2 on January 20, 1970, 09:47:54 AMquote author=NARSES2 link=msg=1029007 date=1705674606]
They must find it an uplifting experience.
Quote from: kitbasher on January 19, 2024, 11:23:05 PM
Actually he's thoroughly embarrassed  :angel:
Quote from: NARSES2 on January 20, 2024, 06:08:23 AM
Quote from: kitbasher on January 19, 2024, 11:23:05 PMThey must find it an uplifting experience.
Whatever pays the gas and electricity bills................  ;D
Probably sick of being asked how many monster sex toys did ya send out today 🙄 🙃  ;D
perttime
Images tend to stay sharp if you can work on them as Vector graphics - as long as you don't go smaller than your printer can handle. Turning pixel graphics into vector can be easy - or very tricky indeed. Depends.
Quote from: Wardukw on January 20, 2024, 10:52:36 AM
To which you reply "why sir, has yours not arrived yet?"
This has to be THE most extreme thread drift ever!  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D
loupgarou
Quote from: PR19_Kit on January 21, 2024, 04:46:13 AMThis has to be THE most extreme thread drift ever!  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D
loupgarou
Having more or less managed to tame my decal paper problem  :rolleyes:  I am proceeding. BTW, I am learning to use the rudiments of Inkscape, as in order to have decent logos, I had to use vector SVG images. The only one I haven't found in SVG is the main sponsor, Honour, had to use a PNG.
A problem is that colours are NOT very opaque,  AND, of course, I cannot print white, so I had to use a white paper, not transparent, moving the logos ver a black rectangle, it leaves some white over the cuts, wil be a mess to retoush.
The "serious" sponsors are a mix of those used by Thrust SSC and Bloodhound.
A question for the forum:
I don't lke the Dunlop "arrow" pointing backward on one side, but it's the way had been done on the Thrust SSC.
I have tweaked the file to correct this. What do you think? Should I change the decal?
One way I've found on minimising the white edge with decals printed on white paper is to trim them with the blade at an angle.
Angle it so the tip of the blade points underneath the decal itself and that means the colour side overlaps the white edge.
It's not 100% but it helps a lot. Here's a sheet I supply with some of my decals for other members here.
