avatar_The Rat
This Cutlass ain't Gutless
Started by The Rat, January 18, 2024, 09:02:22 PM
Quote from: PR19_Kit on February 28, 2024, 03:26:46 AMTwo Avons, that'd sort it.  ;D
Durn tootin'! I'm wondering if I might have to derate them in case the wings tear off.  ;D
Spino
Quote from: The Rat on February 28, 2024, 03:55:35 AM
Probably not, the F7U was tough if nothing else.  It could handle 16G maneuvers apparently, I doubt even a pair of Avons could make it go fast enough to bother the wings  ;D
Some tubing allows for those Avons to chuck a lot more out the back end. I'll be increasing the size of the innards later.
I  like power ..and I like it when it's a ton of power and the bill fits very nicely here 👌  ;D  ;D
Always liked the Cutless as it one of those strange planes when ya look at everything else...this I'll keep watching  mate  ;D
Quote from: Wardukw on March 04, 2024, 07:54:01 PMI  like power ..and I like it when it's a ton of power and the bill fits very nicely here 👌  ;D  ;D
Until the B-2 came along, the Cutlass was the closest the American military had to a flying wing in service. Not quite, but close.
Spino
If it hadn't been underpowered, it might have performed very well against the MiG-17s in Vietnam...
Of course that assumes that it had the right armament, Sidewinders and Mk-12 cannons most likely would have been the best choice.
Spino
Well apparently Vought was kicking around the idea of redesigning the entire rear end of the Cutlass to add wing area and fit a single J57-P4 in place of the twin J-46s. Not sure if they meant to use the P4A with afterburner (16,000lb of thrust) or a version without AB, but either way that could also have turned the Cutlass into a real fighter instead of a lemon - except they were doing all that redesign work for a ground-attack variant...
Even with a J57-P4A, the thrust output wouldn't be as good as two Avons, particularly if they are the kind that the Lightning had, but it still would have been a huge improvement over the terrible engines the Cutlass had.  Makes me want to build one myself sometime, likely 3D-printed due to my limited budget.  Thankfully I'm fairly handy with Solidworks and Blender...
Scotaidh
#29
When I built my J79 Cutlass I did a ton of research - reading pilots' stories, and so on.  Turns out that not only were the engines - the only ones available at time of build - not powerful enough, but Vought built it with a 3000psi hydraulic system - which operating pressure was more than double what previous &Y in-service Naval aircraft used.  So when an original piping part failed, it was usually replaced with ... something already in stock!  (Tell me you didn't see that coming!)  A half-inch fitting is a half-inch fitting, right?  So now you had sub-spec parts just waiting to fail and spray hi-press. oil all over the insides of the aircraft, including those oh-so-hot internal afterburner nozzles ,,, Can you say Fire!  I knew you could ...
I found, that when I showed pics of my Whiffy Cutlass to "non-aircraft people," so to speak, they had no idea what my changes were.  Anyone else have this problem?
I then came up with the idea of making and OOB to put next to the Whiff - but that effectively doubles the price of my builds.
