avatar_Dizzyfugu
1:72 Wedell-Williams P-42A 'Kestrel', 18th PG USAAC, Hawaii, 1941
Started by Dizzyfugu, February 19, 2024, 12:00:11 AM
I was convinced it was a Seversky in a whif paint job, but hey, what do I clearly not know?!
Excellent build, Dizzy.
SPINNERS
Vulcan7
Beautiful paint job, scheme & photos, especially where the propeller motion looks spot-on!  :mellow:  :mellow:  :mellow:  :thumbsup:  :thumbsup:  :thumbsup:
Quote from: SPINNERS on February 21, 2024, 07:43:08 AMNice one Dizzy! I especially like the fuselage stripe.
Thank you. I was looking for "something extra", beyond the diagonal stripe, and that thin red lightning stripe appeared appropriate. Turned out nicely, because it's pretty thin and the red is a bit brownish, so that it's not too prominent. But it stretches the hull visually, and looks plausible, too.  <_<
Quote from: Vostoc7 on February 21, 2024, 07:43:28 AMBeautiful paint job, scheme & photos, especially where the propeller motion looks spot-on!
Thank you. In most cases the prop is actually spinning - no CG effect beats the real life blur in a picture, and that's why I convert most of my prop aircraft builds with a metal axis behind the propeller and a scratched adapter inside of the engine.
comrade harps
Whatever.
Vulcan7
Quote from: Dizzyfugu on February 21, 2024, 11:55:43 PM
Cool, yes real motion nearly always looks better, I use a hair dryer on mine but never tried a metal axis (beyond my skills I think  ;D ) :mellow:  :mellow:  :mellow:  :thumbsup:  :thumbsup:  :thumbsup:
The metal axis is just a trick to reduce resistance, and it allows to finish the prop independently from the fuselage, another side benefit and IMHO worth the effort.  ;)
Vulcan7
Quote from: Dizzyfugu on February 22, 2024, 07:01:11 AMThe metal axis is just a trick to reduce resistance, and it allows to finish the prop independently from the fuselage, another side benefit and IMHO worth the effort.  ;)
Worth the effort for sure  :thumbsup: , (shame the CG ones break the illusion)  ;)  :thumbsup:
Glenn Gilbertson
