The Scimitar FB-2, the RAF's heavy hitter
Started by PR19_Kit, March 15, 2024, 04:10:56 PM
An upside-down pylon under a wing?
Quote from: Gondor on June 04, 2024, 12:06:11 AMAn upside-down pylon under a wing?
More fundamental than that I'm afraid. :(
Quote from: PR19_Kit on June 04, 2024, 09:22:23 AM
Oh. My. GOD! Did you install the rudder pedal tensioners with metric nuts instead of a Whitworth thread?! Quick, put a pilot in the cockpit, maybe his boots will hide it.
 ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D
But no....................
Left main gear on the right side and the right main gear on the left side?
Been there, done that, bought the tee shirt, wore it out, bought another.  :banghead:
You didn't scribe the panel lines for the compartment the crew would use to stow away their overseas deployment expenses cash?
Quote from: kerick on June 04, 2024, 09:53:42 PMLeft main gear on the right side and the right main gear on the left side?
You got it spot on!
And it's impossible to correct now that they're a) superglued in place and b) due to the design of the parts. Once they're in place they're there for good.  :banghead:
So the wheels are inboard of the legs rather than outboard, and the outer doors won't fit, so I'm scratching some styrene ones that will. Luckily the wing mounted tank and that BIG bomb make good visual barriers to oberving my stupidity.
Quote from: PR19_Kit on June 05, 2024, 12:50:41 AM
You got it spot on!
So the wheels are inboard of the lags rather than outboard, and the outer doors won't fit, so I'm scratching some styrene ones that will. Luckily the wing mounted tank and that BIG bomb make good visual barriers to oberving my stupidity.
I have just looked at my Skybirds 86 Scimitar kit and I see what you mean. Oh well, Kit's Rule #2 comes into play I suppose.
Makes it even more of a wiff now ..which is power for the course in wiffy building world  ;D
Quote from: Gondor on June 05, 2024, 01:07:08 AM
You got it spot on!
Apply one of my rules - If no-one ever sees it then it never happened.
Quote from: Wardukw on June 05, 2024, 02:31:04 AMMakes it even more of a wiff now ..which is power for the course in wiffy building world  ;D
Yep, that'd work.  ;D
Quote from: zenrat on June 05, 2024, 03:24:14 AM
You got it spot on!
It just doesn't matter!!!!   Bill Murray in some kids baseball movie.
Well, try as I might, I'm not going to get the FB2 done in time for tonight's deadline.  :banghead:  :banghead:  :banghead:
I spent much of y'day drawing up the decal sheet for it, and test fitting some paper samples to ensure they fit the FB2's curvy fuselage, but could I find the decal paper to print them off? Could I thump!!!!!!
I've searched and searched all over this chaotic house and I can't find the paper anywhere, darn it.
Hmm...I was convinced it ended next Friday.  Ah well.....
