avatar_mat
Douglas D-557C - French service
Started by mat, March 16, 2024, 07:12:08 AM
mat
Found a useable canopy in my scrapyard- think it's from ancient conversion kit from the german Airmodel.
mat
#17
The Airmodel canopy have been cut down, and I've initiated the construction of the cockpitt section, which will later - in a miraculous way - be mated to the fuselage. How I don't now yet, but I gamble on, that like John Lennon, inventing the name "The Beatles", I will have a dream where a little man on a burning cake will deliver the answer.
Quote from: mat on April 04, 2024, 03:59:33 AMThe Airmodel canopy have been cut down, and I've initiated the construction of the cockpitt section, which will later - in a miraculous way - be mated to the fuselage. How I don't now yet, but I gamble on, that like John Lennon, inventing the name "The Beatles", I will have a dream where a little man on a burning cake will deliver the answer.
 ;D  ;D
mat
Fuselage and the cockpitt section have been joined, and some PSR have been taking place to make it fit. Now it's time to fill the cockpitt with stuff. Did the D-557C have bangseats? In the what-if world it probably will.
Quote from: mat on April 13, 2024, 09:05:01 AMFuselage and the cockpitt section have been joined, and some PSR have been taking place to make it fit. Now it's time to fill the cockpitt with stuff. Did the D-557C have bangseats? In the what-if world it probably will.
In wiffy world you can bet they did 😏  :thumbsup:
63cpe
interesting build Mat. Great work so far.
Love to see it finished. Maybe it would have operated along my Coutelasses on French Carriers?
Keep on modelling!
David aka 63CPE
mat
The D-557C was powered by an Westinghouse X25D2 turbine mounted in the rear of the fuselage. So the model need an exhaust from the turbine.
The exhaust part glued on. Now it need some PSR to make it fit with the wing and rear fuselage.
Very cool. Love the big Douglas singles.
X25D2 specifications.
D: 33"
L: 173.5"
W: 2,540 lbs
3,300 hp + 980 lbs residual thrust
From here:
Aircraft Powerplants 1946
It's on of the reasons I like the Skyraider and anything that even resembles a Skyraider..its big brutal appearance..this one is right up that alley  ;D
mat
The nose job
Now its time for adding wings and tail planes
63cpe
That a serious kitbash. I like it!
Nose job looks like it'll get a new identity. What kind of intake did you use?
David aka 63CPE
loupgarou
Wow! Really an heavy conversion, or should I say scratch-build?  :thumbsup:
