avatar_The Rat
Securing a pilot figure for painting
Started by The Rat, March 25, 2024, 06:39:55 PM
Keep some of your empty paint bottles, they can be used for a number of things, like this: piece of double-sided tape, and plonk his butt down on it.
Need to saw something that's small, and want it secured? Piece of double-sided tape, stick it on the surface of your work bench, stick the piece to it, and hack away.
I was thinking of glueing a sprue stick to his butt. Your idea will work much better.
Quote from: kerick on March 25, 2024, 07:17:28 PMI was thinking of glueing a sprue stick to his butt. This would work even better.
You can just leave it there instead of finding some place to stick it, it isn't going to fall over.
By "this" I meant the paint jar. Sorry :rolleyes:  I edited the post to correct my writing and make myself clear.
I would have to make the jar a color I wasn't going to use anytime soon until I emptied one or the paint went bad. A little weight in the jar might help it not tip over when my clumsy hand whacks it.
Quote from: kerick on March 25, 2024, 07:17:28 PMI was thinking of glueing a sprue stick to his butt. Your idea will work much better.
That's what I sometimes do, too, even though I more frequently use thin pincers and hold the figures at their feet/boots. Another (though certzainly controversial  :rolleyes: ) method: drill a hole into the butt (or use a hot needle, ouch), and put the figure on a toothpick. Allows a better field of work.
I use Dizzy's second method.
1.2mm drill up the clacker and then shove a toothpick up the hole.
Quote from: zenrat on March 26, 2024, 03:11:00 AMI use Dizzy's second method.
I do this under the feet on 1/35 or 1/48 figures that will be standing.
If they're seated figures, though ... Well ... Sorry, mate, butt plug it is. :wacko:
I'll have to see if I can find some of that tape and try the Rat's method. A nice fat bottle to hold on to could be easier on the arthritis.
Quote from: kerick on March 26, 2024, 07:30:59 AMI'll have to see if I can find some of that tape and try the Rat's method. A nice fat bottle to hold on to could be easier on the arthritis.
Harbor Fright has a $20 articulated vise you can use for the butt plug method if the bottle doesn't necessarily work (pose, weight, size, etc.).
A piece of dowel with some stickum of some sort on the end - tape, blutack etc. whatever yer poison.
Basically the same principle as the dop stick used in lapidary work.
I use a clothes peg with Blu Tack, and for pretty much any smaller pieces.
Don't use florist foam for anything around painting! Little bits end up everywhere. I used it to shove the bamboo skewers I had glued mini clothes pins too. Bad combo.
killnoizer
I always use a fine pincer and hold one of the boots , fixed the pincer with a small bracket . If the complete Figur is painted I do the boots at last step  . There are many, many cockpits where you don't see them , or it ist not enough space for the complete legs , so I have to cut them of ....
Quote from: killnoizer on March 27, 2024, 06:43:16 PMso I have to cut them of ....
Been there, done that. I just put it down to Douglas Bader being a test pilot.  ;D
Quote from: Mossie on March 27, 2024, 02:37:16 PMI use a clothes peg with Blu Tack, and for pretty much any smaller pieces.
I use similar but with some double sided tape I got from Poundstore. I find it can be a little difficult to remove all of the  Blue Tack from a part.
Also got various sizes of clothes pegs. The small ones were meant for hanging Christmas cards but the intermediate size ones I swear are for dolls clothes  :unsure:
