avatar_Gondor
DHC-1 Marmot
Started by Gondor, April 02, 2024, 11:58:50 AM
Purchased to replace the Focke-Wulf Fw 44 Stieglitz (Goldfinch) in the late 1950s, the DHC-1 Marmot as it was called in Switzerland, was used as a basic trainer for many years, being retired in the late 1980s.
The Marmot differed from most DHC-1 Chipmunks by having an Avco Lycoming O-360-A4A engine fitted as well as a bubble canopy which the Swiss had deemed as essential to help both student and instructor with their all-around vision, there are lots of mountains that could be flown into in Switzerland after all. The increased power of the 180hp Lycoming was also a welcome improvement.
The use of an Avco Lycoming engine prompted Richard B. Stratton to perform a similar conversion for use by the British Gliding Association.
I gave the Marmot a spray of Gloss appliance white after masking off the interior parts that I had previously painted black. I'm never very happy with spraying rattle cans but at the moment it's that or a hairy stick and the can is quicker, well maybe. It was a little later that I was checking the parts for the build when I found that some parts I was going to use couldn't be found  :banghead:
Not sure if it's because I have separated them or because they were not there to begin with. This getting old thing is not doing my memory any good  :banghead:
Anyway, Scalemates and look up the DHC-1 in 1/72, a nice company in Belgium has the version I want in stock so they received an order for one from me. It slows the build down a bit because the engine is different, almost all of the rest of the airframe is the same so I can keep going. I could be sticking bits together in the near future.  :thumbsup:
Pics please my good Sir 👍
This has me interested 😄
Quote from: Wardukw on April 14, 2024, 11:08:59 PMPics please my good Sir 👍
Not much to see at the moment other than some badly sprayed parts on a sprue.
Quote from: Gondor on April 14, 2024, 11:35:45 PM
Yeah which reminds me to check the paint work on the Corsair now it's dry 😒
Defo sounds interesting !
