avatar_killnoizer
Bugatti 35 C
Started by killnoizer, April 18, 2024, 02:03:40 PM
killnoizer
Just another vehicle to build , this was a Vintage AIRFIX Bugatti in 1:35 .
I will ad some parts from other kits to make a new version of the classic race car  :thumbsup:
It's a Land Rover, NOT a Jeep . Like a Jeep, but for gentlemen.
https://www.spacejunks.com/
A V10 engine? That's new................
killnoizer
..and some more coming soon 😆.
The exhausts are from a Mosquito Fighter .
killnoizer
Step two ... Some Interieur , and the high tech construction of the rear axle 😜 .
Front axle is the Nr.4 left over from the sdkfz.232  . That needs some more work to fit in.
Time to think about the wheels and tracks ...
perttime
"tracks" ??
So, this is going to be something different  :wacko:  :wacko:
killnoizer
I made the wheels , now it is necessary to make a break and let it dry ....
Yes TRACKS  :thumbsup:
Quote from: perttime on April 20, 2024, 11:42:40 AM"tracks" ??
A snow speeder ?  ;D
killnoizer
Dirt , not snow  :thumbsup:
Today started with the chains ...
killnoizer
#8
I make a sh.... mistake with the axles , they are not at the same space front/ rear , so i have to cut the rear one on each side and place a spacer in .  Therefore i need the help of a buddy at the club meeting tomorrow evening .
The track construction went very well but each part needs a lot of fine work at the details ..
That is exact that kind of shape i wanted 😁 .
perttime
That is pretty wild  :thumbsup:
I'm curious to see what goes into the cockpit. Somehow, I'm not sure that a steering wheel would be quite right.
killnoizer
#10
Quote from: perttime on April 24, 2024, 09:31:05 AMThat is pretty wild  :thumbsup:
That's a good suggestion ,  but the basic dashboard is mounted in place .
I will try my best , and not shure if i would place the pilot in the cockpit or beside the vehicle .
Steering wheel can work, you just need to use hydraulics for the steering brake & clutch systems linked to the steering wheel.
perttime
I didn't think of that.... Hydraulics in 1920s (and after) should be feasible, unless it can work purely mechanically.
It would be perfectly feasible to have a mechanical linkage connected to the steering wheel which operated brakes to steer the thing.
And you don't need to show it, just tell us it's there.   :mellow:
killnoizer
Bugatti could choose another way , they don't control the brakes , instead they use one engine bank for every side of the transmission and control each accelerator with mechanical levers   :thumbsup:
