Title to follow
Started by The Wooksta!, April 19, 2024, 01:33:32 PM
"Big" is a highly appropriate word! :o
She looks good, though! :thumbsup:
Sanding off the filler on the starboard wing root was a pain, as it is not easy to handle given it's size.  Port was relatively easy.
It may even see the first coat of paint over the weekend...
Quote from: The Wooksta! on July 11, 2024, 02:57:52 AMSanding off the filler on the starboard wing root was a pain, as it is not easy to handle given it's size.  Port was relatively easy.
It's a right-handed, left-handed thing Lee. I have had similar problems when sanding some things. You just have to turn things around and around until you find an angle or direction that is easier than the rest.
I'd give my right arm to be ambidextrous...
 ;D
Hat, coat, gone...
Managed to get a coat of primer on, so I'm now sorting out the myriad dings, scratches and dimples that need sanding off, filling a few holes that the primer highlighted as well as reinstating some panel lines.
I might even get some paint on tomorrow.
She's a big beast, that's for sure
Certainly hasn't shrunk any since the last images! ;)
"This calls for a celebration!  Vyv, throw another record player on the fire!"
Happy with the second primer coat after fixing the various dings, etc.
Time for some paint!
That's looking VERY serious now.  :thumbsup:
And as if by magic...
That's the lighter of the two greens...
There's some areas where I'll need to polish it back and a few that need another coat, but very happy with it so far.
Every time I see this monster it gets more and more impressive...smegging excellent stuff Lee  ;D
I'm imaging this in 48th  :wacko:  :wacko:
Quote from: Wardukw on July 14, 2024, 12:22:04 PMEvery time I see this monster it gets more and more impressive...smegging excellent stuff Lee  ;D
Mine isn't up to that task... or twisted enough...  ;D  ;)
Absolutely! :thumbsup:
Quote from: Wardukw on July 14, 2024, 12:22:04 PMI'm imaging this in 48th  :wacko:  :wacko:
That's just crazy-thinkin'! :o
Mind you, I still want ICM to bring out a 1/35 CH/MH-53D! :wacko:
After a tad sanding and polishing then a second coat.
