avatar_zenrat
Fairey Tinydyne.
Started by zenrat, May 05, 2024, 03:59:33 AM
Quote from: Rick Lowe on April 10, 2025, 10:27:17 PM'Not Easy' you say... does the term 'Rocking Horse Poo' mean anything to you?  ;)
😆 ...Rick mate I'm watching one on trademe right now lol
I built the Rotodyne back in the early '70s and two of the hinge pins were broken off and the other two bent almost to the breaking point. I think it's just poor mould design that causes them to hang up on ejection if everything isn't set up just right.
First one I built (from the last repop before this one) had intact hinge pins.
I finished cleaning up the props today and primed them and the rotor assembly.
Well it was always going to happen.  I broke a rotor blade off today.
I drilled and pinned it and then reinforced all three with jumbo paperclip wire (1.2mm diameter).
Tinydyne WIP 18-04-25 by Fred Maillardet, on Flickr
Impressive engineering  :thumbsup:
I vital step with 'dyne rotors I'm afraid, they're just too thin. But then most model chopper rotors are too.
They are OK if you build them OOB.  But then there is no detail.
Catch 22.
So true, the Revell 'dyne is much better from that point of view, just a silly scale.  :banghead:
