avatar_zenrat
Fairey Tinydyne.
Started by zenrat, May 05, 2024, 03:59:33 AM
Quote from: zenrat on May 23, 2024, 03:15:24 AMI bought two 'dynes.  Can you guess what the off cuts will be used for...   :mellow:
Fuselage extension on a Bristol Belvedere? :unsure:
I refuse to be drawn, on the basis that I'm trying not to be silly  :angel:
The Maxi-Dyne?  ;)
Outrigger pods on the wing tips  :rolleyes:
Quote from: PR19_Kit on May 23, 2024, 06:41:30 AM
The Maxi-Dyne?  ;)
Spot on.  Even the name is right.  It'll be longer with longer wings.
But first, the Tinydyne.
I've cut the nose off and glued both ends back on.  Next task is to figure out where to cut to shorten the rotor mast.
Quote from: zenrat on May 24, 2024, 05:37:46 AMSpot on.  Even the name is right.  It'll be longer with longer wings.
Of COURSE!   ;D
I plan to cut down the Tinydyne wings swapping the severed ends with the tips of what will become the Maxidyne wings.
The June issue of SAM that's just dropped through my letter box has a build of the re-issued Rotodyne in it, straight out of the box.
The Maxi-Dyne?  ;)
I rather like the sound of the Megalodyne, even if it sounds more like a dinosaur than a flying machine.
Quote from: Rheged on May 24, 2024, 07:33:22 AMI rather like the sound of the Megalodyne, even if it sounds more like a dinosaur than a flying machine.
I think it should be called that because it sounds like a dinosaur  :thumbsup:
Quote from: NARSES2 on May 24, 2024, 06:19:16 AMThe June issue of SAM that's just dropped through my letter box has a build of the re-issued Rotodyne in it, straight out of the box.
Do they mention the 'broken-in-the-box' rear door hinges?
I'm enjoying this 😆 🤣
Tinydyne..maxidyne and megalodyne ..you've got to get another one now Fred 😊😊
Or maybe 2 more  :o
Megadyne would be four engined.
Today I chopped half the mast off.
loupgarou
Quote from: zenrat on May 25, 2024, 04:39:19 AMMegadyne would be four engined.
More difficult/boring will be cutting the rotor blades to shorten them, and later adding the bits to the Megalodyne ones,,, :rolleyes:
And what about the tail size?  ;D
Quote from: PR19_Kit on May 24, 2024, 09:22:43 AM
The builds by Bruce Leyland Jones and his only mention of any hinges is that as he built it with the rear clamshell doors shut he could ignore them.
