avatar_frank2056
1/35 Prospector
Started by frank2056, May 10, 2024, 07:54:21 PM
Quote from: kerick on May 12, 2024, 08:29:42 AMDonkeys have a much more rough and scruffy look than a horse. I've no idea how you would do that.
You can see why I'm interested in how  Frank is  going to paint this cause the guy I'm going to build is a Chaos corrupted knight from Warhammer..not sure which chaos god this dude will be corrupted by yet but his horse won't be pretty and a donkey might be a good basis for its paint job.
Quote from: Wardukw on May 12, 2024, 11:27:58 AM
Or a bison!
frank2056
#17
Here's what I did to the donkey today:
I applied some Tamiya extra thin on the plastic, waited a bit and stippled the surface with a brass scratching/scuffing pen like this:
It looks better in person, but this where it was with a basic coat and some white on the underside, head and snout:
With some of the blankets painted and some shadowing on the fur. Here's a donkey in the air for your enjoyment:
It looks a bit more realistic at normal viewing distance. I should have been a bit more aggressive with the glue and brass pen, but it looks OK.
Nice shaggy donkey... that is working really well
On painting horses.. there are many techniques out there. One of the best tips I find useful is around getting the sheen of a horses coat. Paint in flat paint, then when dry, run your fingers, down/along the coat a couple of times. Using the natural skin oils gives a nice subtle sheen with a bit of variation that a satin paint coat does not seem to match.
Quote from: buzzbomb on May 12, 2024, 07:47:23 PMNice shaggy donkey... that is working really well
That's a useful idea - I've seen it mentioned for other things that need a slight patina - though getting your fingers into some of the tighter areas could be interesting.
What about a rub with a paper towel, or chamois cloth?
perttime
What about.... dry brushing to highlight textures?
Quote from: Rick Lowe on May 12, 2024, 10:40:31 PM
It's the skin oils that do the work, can you get enough on a paper towel or chamois cloth to do the job? :unsure:
It is indeed, looking very good  :thumbsup:  :thumbsup:
Quote from: buzzbomb on May 12, 2024, 07:47:23 PMOn painting horses.. there are many techniques out there. One of the best tips I find useful is around getting the sheen of a horses coat. Paint in flat paint, then when dry, run your fingers, down/along the coat a couple of times. Using the natural skin oils gives a nice subtle sheen with a bit of variation that a satin paint coat does not seem to match.
That's a fascinating idea  :thumbsup:  Would you be able to "seal" the coat though without negating your efforts at getting that shine ?
In the Middle Ages, theologians used to argue about how many angels could balance on the head of a pin.  Frank appears to be demonstrating that even a donkey can do the same!
frank2056
Almost done.... still need a couple of bits:
Skeleton Pass is a small pass in the Mojave Desert between a small mountain and a large hill covered in a jumble of boulders. The pass opens up onto a plain...in the middle of nowhere, and if you look at it on a map, it doesn't look too imposing of a hike. I've been there and it was brutal; not so much the heat but the small rocks and the uneven "road":
The kit just has you glue things on. I think the tools needed a strap. I hope the donkey doesn't get poked by that pick...
I'll have to fix the floating prospector. He's actually on the groundwork, just not all the way in.
Donkey looks a bit cross:
Womby, I wasn't meaning impregnating the towel/cloth with the oils; rather using the very slight abrasive/smoothing action of the material to get the same effect.
Quote from: frank2056 on May 13, 2024, 06:15:21 PMI'll have to fix the floating prospector. He's actually on the groundwork, just not all the way in.
Not cross, he's just trying to figure out how the prospectors floating  ;D
Terrific work sir  :thumbsup:
I'm not going to mirror Chris words but damn he's right ..great work mate 👌  :wub:  ;D
frank2056
I could spend days fixing minor details... but I'll call it done:
Anti-gravity boots turned off:
Top view of all cargo on the donkey:
I turned the kit's rifle into a Winchester, 1873-ish...
... by taking out a section, bending the stock and making the elliptical thingamabob behind the trigger out of 30 gauge wire:
With his pals. Looks like we've been spotted:
Thanks for all the comments!
