avatar_Dizzyfugu
DONE +++ 1:72 Lockheed-Detroit P-22A 'Alcyone', USAAC, 1935
Started by Dizzyfugu, June 08, 2024, 12:22:29 AM
First entry, and work has already begun this morning. This will be an interwar biplane project, based on an ICM Ki-10 kit with some mods (spats!) and a VERY bright livery. Should look very pretty once it's done. Ambitious, but, hey, it's a WHOLE week of time...  :lol:
A week?! You should have three or four done in that time, going by your usual completion rate!  ;D
Results after Day #1; the Ki-10 is a beautiful and very sleek aircraft, and while I want to keep as much of that as possible I decided to add a bit more speed to the overall look. Therefore the upper wing was cut and modified so that the now gull-shaped wings could be directly attached to the fuselage, similar to a Polikarpov I-153:
1:72 Lockheed-Detroit P-22A 'Alcyone'; aircraft '62' of the United States Army Air Corps' (USAAC) 95th 'Kicking Mule' Pursuit Squadron, 17th Pursuit Group; March Field (California/USA), 1935 (What-if/ICM kit) - WiP
by Dizzyfugu, on Flickr
Propeller was also modifed to accept a metal axis, as ususal. The cockpit was - according to color pics from museum a P-12 and P-26, in a light grey, with a full-metal seat, and the pilot recieved a headrest (piece of sprue and PSR) to change the lines a bit and offer some protection in case of a somersault on the ground.
Mounting the wings without fixation aids/points was not easy...
...but eventually worked, and it looks good!  :lol:  The (modified) wings´ struts/supports were added next, and the machine will furthermore receive a more streamlined landing gear with singe struts and spats, IIRC left over from a Hasegawa SOC. These required proper attachment points on the hull, so that I had to add the small bulges in front of the lower wing roots.
Some detail work and PSR still to do, but painting stage is already approaching fast - still a long way to go, though!
Yep..Dizzy doing a epic build again and moving like lighting at the same time  ;D  :o
loupgarou
The real world Curtiss XP-22 led to the P-6E via a very convoluted path involving the YP-11/YP-20. ;D
The earlier Curtiss XP-10 had a gulled upper wing like Dizzy's model, and a slight inverted gull on
the lower wing.
 :o  :o
Seriously it would take me a week to get the yellow wings looking anywhere near that good, and I'm only half joking.
