avatar_zenrat
McDougall Donald F-45 Pheagle. Finished pics pg 8.
Started by zenrat, June 08, 2024, 03:38:01 AM
Quote from: PR19_Kit on July 30, 2024, 04:32:56 AMAt first you think 'Oh yes, an Eagle', but then you look again and go 'Errrrmmmmmmmmmmmm..........................????'  ;D
:wacko:
Very much so
Today I fired up the air brush and painted 18 bombs.
I also sorted out a tank for the belly hsrdpoint.
This is going to look even better with a load out. A couple of Sidewinders or Slammers in the mix?
Quote from: kerick on August 04, 2024, 01:33:36 PMThis is going to look even better with a load out. A couple of Sidewinders or Slammers in the mix?
Not at the moment.  But that might change.
Currently 18 SUU-30's and a big shiny tank on the centreline.
Bombs and tank are in place...
...but i then found some 'winders and a couple of double mount hardpoints and i'm fitting them under the intakes.
Also started on the back story.
Backstory developing mind of its own and going in some strange directions.
Quote from: zenrat on August 07, 2024, 05:16:52 AMBackstory developing mind of its own and going in some strange directions.
I'm told a lie down can sometimes help  ;)
Quote from: NARSES2 on August 07, 2024, 06:27:48 AM
Following a good nights sleep I toned it down a bit to avoid possible complaints.   :wacko:
Nearly done.  Model as well.  Just got to put another goat of underside on the missel pylons and add some colour to the missels noses.  And then superglue them into position.
Quote from: zenrat on August 08, 2024, 05:52:24 AMNearly done.  Model as well.  Just got to put another goat of underside on the missel pylons and add some colour to the missels noses.  And then superglue them into position.
 :blink:
Have you been sniffing the glue again, Fred, or do you need to get better ventilation in your modelling space? :unsure:
Quote from: Old Wombat on August 08, 2024, 07:20:22 AM
 :blink:
Obviously AI is doing its "take care of humanity" thing and changing the words. It's for our own good you know.
More likely to be due to inhaling thinners than glue fumes.   :o
Although I do use a big fat stinky texter (marker pen) at work to redact bar codes on reused packaging.  That has a heck of a kick to it.
Nothing more done to this today - no bench time.
Quote from: zenrat on August 09, 2024, 04:57:23 AMAlthough I do use a big fat stinky texter (marker pen) at work to redact bar codes on reused packaging.  That has a heck of a kick to it.
 :unsure:  Is this where people bring in a package they want to post but it has an existing bar code on it ? I'm confused. Not sure if Royal Mail/The Post Office here in the UK offer the same thing.
