avatar_The Rat
Fuerza Aerea de Chile Spitfire Vc
Started by The Rat, June 24, 2024, 06:30:33 PM
No back story, just another model to try new things, like airbrushing and decal printing. The former worked fine, the second, not so much. This printer just doesn't lay down the colors thick enough. Each Chilean roundel on there is doubled, one on top of the other, and still not enough. I put squares of white underneath to allow for the stars, but it shows through the decals. Kit is the Airfix 1/72nd issue, not bad but the canopy is naff. Also played around with a bit of photo editing.
Chilly Chilies in Chile, Batman! :o
Nice work, Rattus! :thumbsup:
Hotte
2996 Victor
Excellent build and very nice camo painting!  :thumbsup:
Mark
Mark's workbench:
Spitfire Mk.I Vichy North Africa - Eduard 1/48
Spitfire PR.XIX Rearward-cockpit - Airfix 1/48
Boulton Paul Valiant Mk.I PR - Airfix 1/48
I would recommend printing the roundels onto white transfer paper and then practising your carefull cutting.
Thank you, gentlemen! I was pleased with the way the desert camo turned out, it taught me that my cheap portable airbrush is up to the task
Quote from: zenrat on June 25, 2024, 03:22:51 AM:thumbsup:
I thought of that, but the shape would not be easy to trim, especially in 1/72nd.
Charlie_c67
How about a using a white square and then touching up the bits that stick out with the appropriate colour? Or a black outline of the roundel on the white decal paper and cutting that out? Means any small bits where it goes a little wrong will be much less noticeable.
