Main Menu
The DC88-126Z
Started by PR19_Kit, June 29, 2024, 04:11:18 AM
And yet more problems.............
I mentioned the awful cockpit arrangements that Minicraft use on their airliners before, and BOTH of the 'canopies' keep cracking away from the fuselage top edge. I've tried re-gluing with liquid glue to no avail, and now I've resorted to supergluing the joints. It's a right pain!
But I have built all the engines I need for the model and their in the middle of their PSR stage now.
Somewhere I have a few sets of SAC white metal landing gear for DC8s, and I'll be looking those out soon. What I'm NOT looking forward to is painting the twenty wheels on this thing!
At first I thought you said the all the engines were in the middle! Read the entire sentence I told myself!
Quote from: kerick on July 11, 2024, 09:09:31 PMAt first I thought you said the all the engines were in the middle! Read the entire sentence I told myself!
They might be now you've mentioned it.  ;D
I've built six of them so far, some may even have been intended for DC8s too.............
Ah, fluid creativity!
Actually there's not enough room to put them ALL in the centre section, they'd need to be touching each other to make that work and that'd look just silly.........
(I'm not quite sure how I wrote the last phrase without collapsing in hysterics!)  ;D
Steel Penguin
under wing and over wing mounts!!
sorry im getting silly as well arnt i  ;D
Both of those are possible, and one of them is even likely.  ;)
Robomog
Hey this is Toph inspired and Whiffworld!  Silly is perfectly acceptable here  ;D  ;D  ;D  ;D
Mog
Quote from: Robomog on July 12, 2024, 03:31:59 PMHey this is Toph inspired and Whiffworld!  Silly is perfectly acceptable here  ;D  ;D  ;D  ;D
Mog
Could not agree more  :thumbsup:
I've realised that the major disadvantage of building something with two fuselages is that you almost automatically DOUBLE the amount of PSR needed.  :banghead:
At last the construction side of the DC9-126Z is done, and that was after UMPTEEN PSR and primer spray sessions, specially over the centre section.
Because of the tight fit of the wings in the fuselage sockets it's vital that the whole thing is sprayed while completely assembled as that keeps the paint out of the sockets etc. and it's a right pain trying to find some way to hold it and not paint my hands as well, but it's done now.
Now it needs colour painting, mostly white, grey and natural metal of course, but there's a large chunk of a rather nice blue over the rear of both fuselages, and luckily I found just the right shade in Halfords, despite their new, totally USELESS method of cataloguing their paints.  :banghead:
In anticipation of some holiday period painting and decaling, I'm off to Norfolk for 10 days or so soon, I've drawn up and printed the MONSTER decal sheets, and this is just one of them, there's FOUR altogether!  :o
That's an A4 sheet by the way, the other sheets are the same size but nowhere near as densely printed, the decals are just LARGE.
I feel sorry for ya kit..well kinda 😅
It's gonna look damn impressive when she's done tho ill bet  :thumbsup:
Also available in white................
Well, half of it anyway. The long port fuselage seems to be suffering a bit from softening of the outside due to gluing on the inside, something I've had before when stretching airliner fuselages because you have to use styrene straps on the insides to strengthen the joints of the add-on bits. It's a pain, but it happens and just needs some MORE PSR, what a surprise!
I've managed to do some re-positioning after deep thinking on the decals and I can get them all onto only TWO sheets now, a big saving.
Quote from: PR19_Kit on July 16, 2024, 02:57:11 PMAt last the construction side of the DC9-126Z is done, and that was after UMPTEEN PSR and primer spray sessions, specially over the centre section.
From that angle it looks as if you could have made the tailplane connect the rear of the two fuselages together with a larger single unit.
I could have, yes, but it was difficult enough scratching up the wing centre section, let alone doing a very long and narrow (and thin....) tailplane as well.
Both fuselages are white now, and I'm trying to figure out how to mask them up for the blue bits, not an easy task.
