avatar_zenrat
Mustang - For Tophe. Finished pics Pg 5.
Started by zenrat, June 30, 2024, 03:47:18 AM
Quote from: Rick Lowe on August 15, 2024, 06:07:15 PMMurphy strikes again, under his alternate identity of Irony...
Murphy is always striking. He should be arrested for assault and battery!
Quote from: kerick on August 15, 2024, 07:41:55 PM
Not a full on occurrence of Murphy's law as I did manage to scribe all the required lines without digging out the filler I was scribing through.
Although maybe it depends whether you take Murphy's law to be "anything that can go wrong will go wrong" or "everything that can go wrong will go wrong.  I am a firm believer in the second version - when Murphy's kicks in it kicks in fully.
While looking up Murphy's law on wikipaedia I found Muphry's law;  "If you write anything criticising editing or proofreading, there will be a fault of some kind in what you have written."
Quote from: zenrat on August 16, 2024, 04:43:00 AMWhile looking up Murphy's law on wikipaedia I found Muphry's law;  "If you write anything criticising editing or proofreading, there will be a fault of some kind in what you have written."
 ;D  ;D  That is oh so true  :angel:
Quote from: zenrat on August 16, 2024, 04:43:00 AMNot a full on occurrence of Murphy's law as I did manage to scribe all the required lines without digging out the filler I was scribing through.
Yep ..every time  :banghead:
Big step forward - wings now attached to fuselage.
Quote from: zenrat on August 18, 2024, 03:35:58 AMBig step forward - wings now attached to fuselage.
Always good to hear!
It's like putting up the walls on a new house. Now you have to deal with all the small parts.
Nice Fred ..it's almost done  :unsure:  :wacko:
I see a Wallis and Gromit scenario. Gromit is in the cockpit flying and Wallis is in the pod screaming!
This looks fantastic! I love the horizontal stab arrangement.
That's simply rad Fred ..love it 😀 😀
ericr
Thanks folks.
Quote from: kerick on August 20, 2024, 10:22:14 AMI see a Wallis and Gromit scenario. Gromit is in the cockpit flying and Wallis is in the pod screaming!
I can see that.
Horizontal stab is made by rearranging the kit parts to echo the wing shape.
I'll have to poke around the junk parts box when I get home from vacation.
