avatar_Robomog
Push-me-Pull-you Spitfire. --- for Tophe
Started by Robomog, June 30, 2024, 08:56:32 AM
Is the stand glued to the model and removed later or does the model just rest on it?
loupgarou
Very sharp idea the paint rig. And could laso be used to adjust the correct angle for the wings while building. I'll rob your idea.
AND, of course, the buld is mucho interesting, looking forward to seeing it completed.
Robomog
#47
Hi all
The aircraft just sits on the stand usually with the uprights in the wheelwells. For tail draggers I make an inverted V and insert a cocktail stick or small sprue through the propellor hole like this.
If its a bit loose I add some blutack to the ends.
Obviously each aircraft is different  that's part of the fun  ;D
Feel free to adopt, adapt and improve  :thumbsup:
Mog
Would you keep that jig for other Spitfire builds or is each one bespoke?
Robomog
Some of the rigs are kept like the Spitfire and Hurricane rigs as I build a few Spitfires and the Hurricane rig is often used for other tail sitter fighters.
Most are bespoke or re-adapted from old ones, like the swept wing Zero rig which was originally an EE Lighting rig..
Mog
Quote from: Robomog on August 09, 2024, 09:14:37 AMSome of the rigs are kept like the Spitfire and Hurricane rigs as I build a few Spitfires and the Hurricane rig is often used for other tail sitter fighters.
Mog
Worthy of a build post in its own right.
Robomog
Thx, I take that as a great compliment  :thumbsup:
Mog
Robomog
Hi all.
Well with a big push over the weekend I'm proud to announce I have completed the twin Spitfire.
Here's the pics :-
Had to give enough ground clearance to clear the prop  so the undercarriage became a bit leggy
Finally for comparison..........
Tophes design.
Finished  article
Really enjoyed the challenge of this one and how it came out. Hope it does Tophes design justice
As always all comments and criticisms gratefully accepted.
Mog
Andrew Gorman
Nice!  Do you have a source for the P in a circle prototype markings or did you make your own?  And the spray jigs are brilliant!
That is fantastic and a great tribute to Brother Tophe!
ericr
 :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:
very beautiful !
the front wheel reminds me of something : would it be from a Skyhawk maybe ?
It does give a very refined appearance to the whole.
A BIT leggy?  :o
They'd have needed some SERIOUS crew ladders to get aboard, but the overall look is 'Pure Tophe' and really looks the part. A superb job.  :thumbsup:  :thumbsup:
Steel Penguin
elegant looking there.   :thumbsup:   from here
Robomog
Thanks chaps, much appreciated
Andrew :- the Prototype markings are from an extradecal sheet. You can get them here
https://www.hannants.co.uk/product/X72213?result-token=vQzqJ
Ericr :- I don't know what aircraft that came from it was in my parts stash and was long enough. But I agree with you it could be from a Skyhawk
PR_19 :- Absolutely!  :thumbsup:
Mog
