avatar_Robomog
Mitsubishi Zero flying wing - for Robert (kitnut617)
Started by Robomog, June 30, 2024, 09:12:56 AM
Quote from: kerick on August 11, 2024, 10:27:33 AM
Quote from: Rick Lowe on August 11, 2024, 12:28:30 AM
Quote from: NARSES2 on August 10, 2024, 11:53:09 PM
Quote from: Robomog on August 10, 2024, 08:30:23 AMWish me luck,  as me and the colour orange have had rocky relationship in the past :o
Mog
Maybe a pale pink undercoat which helps when painting yellow could help ?
It would certainly make it deeper/richer.
Worth an experiment, methinks.  :thumbsup:
Let us know the results.
We expect a full scientific paper.
Abstract
Hypothesis
Methods
Data
Analysis
Conclusion
Peer reviewed for publication in the Global Whiffery Association journal.
That's one thing I like about Ken ..he doesn't ask for much and he ain't demanding  :o  ;D  ;D
But yeah he's right thou and it's gotta be in New Times Roman 🤘
Robomog
What, not Comic Sans ?  :wacko:
Ah, thanks for the suggestions guys but sadly I've already started so it will be on base white.
I will keep the advice I  mind for future builds and I will break with tradition in that I'll give you a sneeky peek of the results before I finish the model
Mog
Quote from: Wardukw on August 11, 2024, 12:41:08 PM
Mog
Abstract
Hypothesis
Methods
Data
Analysis
Conclusion
Nah, too much like work... bone idle, me.
Quote from: Robomog on August 11, 2024, 05:03:47 PMWhat, not Comic Sans ?  :wacko:
Nope, Wingdings or Hieroglyphs only! None of this 'Modernism".
Robomog
Right I'll break out the quill pen........
Or maybe hammer and chisel  ;D
Mog
Robomog
As promised here's a sneeky peek of the colour scheme.
It's very bright and glossy but I'm hoping to dull it down with a couple of coats of matt varnish.
The underside is a bit patchy I'm hoping the varnish will level things out a bit.
Should be finished soon
Mog
Certainly looks like what I think of as Japanese Trainer Orange.  :thumbsup:
You're also not going to lose it in a hurry... unless you put it beside/in a bowl of Pumpkin Soup... or a field of Nasturtiums...  ;D
Robomog
Thanks chaps, finished model coming soon..........
Mog
Robomog
#55
Hi all.
Finally finished, once again a very gangly undercarriage, I had to allow at least a wheels height so that the prop clears the ground. The undercarriage looks a bit funny perhaps i should have angled the leading wheel forward a bit but it is what it is now.
heres the pics :-
A very gangly undercarriage!
A couple of scale shots with Arthur Brain and the Yellow Landrover
Like the Twin Spitfire a substantial ladder is required to get to the cockpit
And Fiinally.....
Concept
Visualisation
Again I had a blast building this one,  it was very refreshing building both this and the Spitfire.
As always, all comments and criticisms gratefully accepted.
Mog
steelpillow
#56
Excellent realization, love it.  :wub:
Yes, working through the nuts'n'bolts of a whiff and bringing them to life is always a relaxing and cheering exercise.
So much better than spending a million on wind tunnel tests and then being told I'd got it only almost right. ;)
Cheers.
Gangly it may be, but it HAS to be unless it's going to get clipped prop blades on every flight.  :o
The colour is OUTSTANDING, both literally and figuratively, and is perfect for the job!  :thumbsup:
Absolutely love this ...super bright orange and with the decals now it seems even brighter..fugure ghat out 😆
Weirdly with the canopy it looks like it's going backwards and forwards at the same time 😁😁
Not a criticism..a very cool feature 😎 👍
