avatar_Wardukw
Triple engined P-38 Schneider Trophy racer.
Started by Wardukw, July 13, 2024, 12:53:58 AM
loupgarou
Fantastic paint job, and is a very elegant plane..
Thank you very much guys 😊 ☺️
Chuffed you guts like this ...I'll admit it did turn out brighter than I thought it would but turns out to be the way to go 😆
Yes I used all the colours and then some ..it was fun 😁 😂
There is another float plane idea I've been pondering over but it's no good for this GB as it's not weird..strange or cockeyed  :wacko:  :lol:
Vulcan7
Simply had to find the time to log in & say FANTASTIC BUILD ALL-ROUND!!! Tophe would have loved this, ticks all the right boxes  ;D  :mellow:  :mellow:  :mellow:  :tornado:  :thumbsup:  :thumbsup:  :thumbsup:
loupgarou
I don't how you could manage all that masking, AND get a perfect result!  :o  :thumbsup:
That looks fantastic!  :thumbsup:  :thumbsup:  :thumbsup:
Mind you, I'm experiencing a sympathetic cringe at the thought of all the masking... :unsure:
Thanks lads   ;D   ;D .
Well that masking wasn't as difficult as you'd think ..to get the half circles that's easy ..I went thru my nuts and bolts and found a flanged nut the size I was looking for ..layed out some 32mm wide ..then drew a centre line and then the diameter of the nut ..then just drew a around the nut..instant circles.
Then cut thru the centre and then I cut out the half circles by hand .
Then I just sat there and tried to come up with a design ..once done the rest they say is history  :thumbsup:
One thing tho..I can't actually remember how I did the engines  :o  :unsure:
Quote from: Wardukw on August 08, 2024, 02:52:54 AMOne thing tho..I can't actually remember how I did the engines  :o  :unsure:
So painful you've erased it from your memory! :wacko:
Quote from: Old Wombat on August 08, 2024, 03:01:28 AM
With my mind Guy mate I know it was a spur of the moment thought which sorted the design and layout and how to do it..then once done my mind would have shoved it aside as it's not considered important anymore.
Quote from: Wardukw on August 08, 2024, 03:20:55 AM[..then once done my mind would have shoved it aside as it's not considered important anymore.
Until the next time you need the same technique...  ;)
I can recommend a circle-cutter, as then you don't have to be concerned about keeping the cutting by hand accurate.
Quote from: Rick Lowe on August 09, 2024, 09:24:20 PMI can recommend a circle-cutter, as then you don't have to be concerned about keeping the cutting by hand accurate.
Yup, one of the few "specialist" tools I've found really useful. I use a simple Ofla one.
Quote from: NARSES2 on August 10, 2024, 05:43:48 AM
Ive got circle cutters ..2 of em ..a simple yellow and blue one and a super duper Dspiae stepless adjustment circle cutter with the locator tool as well 😀
That thing will cut a circle 3mm round if ya want too ..it's an amazing piece of kit 👌.
The cheap plastic one I've got sucks pretty much..it's made from plastic which is too soft so it flexs and twists as ya try to cut with it..if the blades were super sharp that would help but even brand new they're not  :banghead:
The nut I used is 19.3mm in dia and I needed practice cutting out things again..haven't done anything circular cutting in yonks..so I cut it by hand  and gentlemen I'll admit..I did enjoy that  ;D
Yeah, the yellow-and-blue ones are useful to a point... usually up to 20 thou card, then they make a nice spiral cut - or a smaller circle than you dialed in, for some reason.
But hey, if you enjoy hand cutting, then more power to ya. It is more satisfying, I admit.  :thumbsup:
Quote from: Rick Lowe on August 10, 2024, 01:20:47 PMYeah, the yellow-and-blue ones are useful to a point... usually up to 20 thou card, then they make a nice spiral cut - or a smaller circle than you dialed in, for some reason.
It's something I'd not done in a damn long minute that's a certainty so I thought why not  ;D
Abd I got to play with some new knifey tools too 😉😁
Quote from: Wardukw on August 10, 2024, 10:23:25 PMAbd I got to play with some new knifey tools too 😉😁
You do realise that AI has just alerted your local constabulary after that ?  ;)  And if you live anywhere near Brokenwood and they send that female cop to investigate can you give her my number ?  :rolleyes:
Yeah, Kirsten is cute, but somehow I prefer Gina...
