Best way to remove frame from clear canopy windshield
Started by jaabdad, July 28, 2024, 02:47:05 PM
Quote from: jaabdad on August 17, 2024, 11:54:17 AM
Quote from: frank2056 on August 17, 2024, 10:22:51 AM
Quote from: jaabdad on August 16, 2024, 02:51:10 PMQuestion is, what adhesive can I use that will be strong enough to hold the 2 parts together yet dries reasonably clear? It'd be great to get something with immediate tack so I don't have to hold the parts together (somehow).
G&S Hypo Watch Crystal Cement is somewhat tacky when first applied, dries completely clear. It's great for attaching clear parts and you only need a small amount - the small tube will last for years.
Good info! I just bought a tube.
Indeed... I've never used that type of glue so i'll be getting one of those myself. :thumbsup:
jaabdad
Test fitting - getting close. Only minor damage to canopy frame...  <_<
jaabdad
Almost. Just need to tweak a bit here and there to smooth the transition from fuselage to windscreen.
There will be a bit of putty work as well to fix the canopy frame.
