avatar_The Chaos
1/32 Revell FW190 F-8 "Finished"
Started by The Chaos, August 01, 2024, 07:23:02 AM
The Chaos
Hello, after the 190 is for the 190.  ;D
Next Projekt a FW190 F-8 with 103 mk canon. In Service of the JG 6 late 1945.
with some accessories.
I still have to get some accessories at the end of August, but I'll probably start on the cockpit when I have time.
The Chaos
I looked through everything and I have the new toll for the 190s. From Hase.
The Eduard stuff is for the old toll from the 70s. Strangely enough.
Here I can see that I have to saw away some of the engine and the machine gun shaft and also have to scrape some of it. I hope that it fits reasonably well.
The cockpit is very detailed and I will just mount the cannon switch for the MK 103.
I have time again on Sunday and will try to see how the cockpit fits into the fuselage.
The Chaos
Toda i becam the next acecories for the build and the right Revell Kit for it.
The Chaos
Evening, today I started with the FW190 and immediately had problems with the Eduard seat belts, the buckles are too narrow to push the seat belts through. So I glued the buckles on.
A-and he's off! :thumbsup:
Took a while, but better late than never! ;)
The Chaos
Continue on the Cockpit parts.
The Chaos
The Chaos
The Chaos
The Chaos
Update.
I began with the Wheelbay and the main Gunbay.
I'll just sit here and admire your work with all the etch  :bow:
