avatar_The Chaos
1/32 Revell FW190 F-8 "Finished"
Started by The Chaos, August 01, 2024, 07:23:02 AM
PSR is ALWAYS with us, such is modelling life.  :banghead:
The Chaos
The Chaos
The Chaos
The Chaos
Update.
I painting the yellow parts.
The Chaos
The Chaos
The Chaos
All parts paintint, next step, Decals.
The Chaos
Update.
Unfortunately the engine didn't fit well, parts of it were warped, I still have to fill and sand it and hope I can get it to a reasonable level in the end so that it's not too noticeable.
The Chaos
Found the culprit.
One of the exhausts was in the wrong place, all parts were removed and when I tried fitting it the engine was straight.
Now I have to repair it.
Kinda looks as if it needed a jig to help get the parts in the correct place and at the correct angle. Looking good though  :thumbsup:
Glad you found the problem  :thumbsup:
The Chaos
The corrected engine, still not perfect but at least it sits in correctly and is straight, should have removed more resin from the pistons so that they sit deeper. Now it stays like this.
