avatar_Old Wombat
The Waffling Wombat
Started by Old Wombat, September 19, 2024, 11:17:13 AM
Have to say that your construction area organisation is mind blowingly good!  :thumbsup:
Mine most certainly is not.. :rolleyes:
Quote from: Pellson on September 22, 2024, 02:47:32 AMHave to say that your construction area organisation is mind blowingly good!  :thumbsup:
That's not what I'd call it! ;D
(It's not what my wife calls it,either. :rolleyes: )
Fuselage is together! :thumbsup:
A little bit of PPP seems (so far) to be all that's needed to fill the gaps,
However, I'll have to do some re-painting of the cockpit, as the kit is pre one-piece cockpit rear bulkheads, so there are seams. :rolleyes:
Still waiting for the 2-part epoxy to cure on the wheel wells (forgot to check if it was regular or 5-minute when I mixed it). Still, should be good & strong when it does. ;)
Quote from: Old Wombat on September 22, 2024, 04:39:30 AM
It looked better before you zoomed out..  ;D
That's not bad at all.
A clean desk is the sign of someone who doesn't do anything!
Well, yesterday not much seemed to get done but progress was good; I got the fuselage & the wings glued together, & the wings have joined the fuselage this morning (currently clamped & taped while the glue dries). :thumbsup:
I get confused by thinking 'Interior Green' should mean as used in the peopled parts... not so, they're 'Zinc Chromate'...  :banghead:
I've tried to keep a tidy desk but I usually can't find the parts that I need, this might change when I return to work as I will have the dosh to buy a filing system.
Quote from: Old Wombat on September 22, 2024, 02:32:55 AMIt gets more confusing when you realise that there were at least two different zinc chromates used, one more "green" (generally used on USAAF aircraft) & the other more "yellow green" (usually used on USN aircraft), then each manufacturer had their own, slightly different, take on "cockpit green".
Exactly  :banghead: Perhaps that's why we Wif, and no I don't mean pong  ;)
Today's update:
Where I was when I went to bed last ... yesterday morning (at Stupid o'clock :rolleyes: );
Where I'm at tonight after midnight (at Not-So-Stupid O'clock ;) );
Had to move the aerial mast back because Hobby Boss thought it should go immediately behind the sliding canopy. :o )
Note the crack in the canopy just in the top rear, where it joins the fuselage glazing - the joys of single-piece canopies with complex shapes & angles. :banghead: )
Bits & pieces awaiting priming and/or painting;
Well, that's all the modelling for today.
Thanks for watching!
 :thumbsup:  :thumbsup:
I do like the P-40 ..ive got one but for some reason the canopy has just disappeared 🤔
Oh I just had an idea 💡 😳 😅
Watch this space ..well not this one ..another one  ;D
Quote from: Wardukw on September 23, 2024, 10:15:51 PM:thumbsup:  :thumbsup:
P-40Q with a bubble? Just a thought...
Quote from: Rick Lowe on September 23, 2024, 10:16:58 PM
Maybe  ;) ..maybe not  ;) 😁
Painting day, today.
The fuselage is primed - just a few little spots requiring a bit more putty-&-sanding, & a few bits of fluff that need buffing out. :smiley:
Prop spinner painted SMS "Italian Red" (which is slightly ironic, when you think about it), & prop tips painted very, very, very pale pink as an undercoat for the yellow.
The instructions say to paint the prop blades "steel", but they're usually black ... Any suggestions (remembering "Real World" (or a moderately reasonable approximation thereof, anyway)?
