Main Menu
avatar_kerick
Skyraider biplane
Started by kerick, September 22, 2024, 07:05:19 PM
Is it possible to place a nose weight in the tip of a float as you cast it? It would help balance it a little.
Quote from: kerick on September 25, 2024, 09:10:36 PMIs it possible to place a nose weight in the tip of a float as you cast it? It would help balance it a little.
Couldn't see why not ..it's just a mold and a weight could be added during pouring the resin ...they put lights..LEDs into resin when poured ..so a weight shouldn't be a issue.
Quote from: Wardukw on September 25, 2024, 11:34:05 PM
You might, I say might because I haven't done chemistry for over 50 years, get some interesting chemical reactions between lead and the resin as it cures ? But hey, "interesting chemical reactions" is what leads to progress, right ?  ;)
Quote from: NARSES2 on September 26, 2024, 12:47:21 AM
I wouldn't think there would be Chris ..resin is just plastic at the end of the day...and the heat it generates ain't anywhere near enough to mess with lead ..it shouldn't anyway ...come to think of it I think ive poured resin on lead before and I don't remember any problems..fact I don't know when either 🤔 😁
ISTR a Canadian website selling aftermarket floats in various sizes.  I probably bookmarked it but my bookmarks are a mess and I can't find anything.
<edit>  Found it.  Alaskan, not Canadian.
https://opland-freeman.com/khee-kha/
Quote from: Wardukw on September 26, 2024, 12:58:01 AM...come to think of it I think ive poured resin on lead before and I don't remember any problems..fact I don't know when either 🤔 😁
Well there you are them, obviously the fumes generated lead to memory loss  ;)
Quote from: zenrat on September 26, 2024, 04:20:48 AMISTR a Canadian website selling aftermarket floats in various sizes.  I probably bookmarked it but my bookmarks are a mess and I can't find anything.
Now there's a site worth saving, thanks Fred.  :thumbsup:  :thumbsup:
Beautiful looking kits. I think the floats might be too smal for a Skyraider but I'll take a closer look later.
Nice ! I'd better get on ordering a few sets of that turbo Twotter !
Quote from: NARSES2 on September 26, 2024, 05:11:16 AM
Hahaha 😀 😆..ya know you might have a point 👉 👈  :o  &lt;_&lt;
Quote from: kerick on September 25, 2024, 06:22:45 AM
Quote from: PR19_Kit on September 25, 2024, 06:18:45 AM
Quote from: kerick on September 24, 2024, 10:12:24 AMI need to find another set of those aero club vacuform floats. They are very handy.
You're not kidding, a superb set.
Sadly they're as rare as hen's teeth these days, but as I have almost a complete set (mins the BIG ones....) maybe they could be 're-engineered'?
Problem is it's the big floats that I can use. I have the remaining medium and smaller ones too. Our club contest and swap meet is Oct 12 so maybe I'll get lucky there.
What about something with a float option, that the builder won't be using?
I managed to get a set of Italeri Ju-52 floats for my C-47 conversion from a guy who wasn't going to be using the option.
If you can't find something big enough, you could widen and lengthen a smaller set?
Quote from: Rick Lowe on September 26, 2024, 10:46:43 PMWhat about something with a float option, that the builder won't be using?
I used the largest Aeroclub floats for my RW C-47C conversion, and even then they needed lengthening to get the correct length. Not mentioning installing the landing gear as well...........
And the biggest pain was NOT aligning the floats directly under the engines. Quite why Douglas moved them inboard a tad defeats me, but they did.
Oh yes, and the VAST amount of nose weight that you need, even inside the floats!
Yeah, I know one nosewheel has fallen off, but it's maybe 40 yrs old now.
