avatar_John Howling Mouse
P-47 SeaBolt
Started by John Howling Mouse, April 01, 2005, 05:54:53 PM
First of my seaplane conversions now underway.
Slightly modified tail (sharper taper).  This will be an unarmed observation plane c/w cockpit for two.  Likely end up in three-tone non-specular USN WWII scheme, heavily weathered.
"Getcha floats, red-hot floats over heah!"
Will be molding then casting these tomorrow.  The largest ones shown here will become the twin floats for the P-47 SeaBolt.  Some other prospective seaplane conversions include:
- P-36
- Me-109 (the JMN's will slaughter me for this, I'm sure)
- Spitfire (not really a What If, though)
- T-Tailed, two-seat Mustang
- Corsair (naturally)
- Dewoitine D-520 (again, I believe this was done in real life, no?)
- P-38 Lightning (if I can figure out how to pull it off)
- AT-6 Texan (Early RCAF yellow trainer scheme...argllllllllghhhh....)
- PB4Y-2 Privateer (someone else here drew a great B-24 Liberator seaplane conversion and that would be great, too)
- Wyvern
- DHC-4 Caribou (with those inverted bent wings, seems like a natural)
Some reverse possibilities (converting floatplanes to land-based) I've wanted to try include:
- Shin Meiwa
- CL415
- Kawanishi Kyofu Type 11 (can anyone confirm if this was already done in reality?  My Tamiya kit has no provision for landing gear whatsoever so I'm looking forward to creating what I *believe* is to be an original aircraft idea)
Others?
Ollie
AT-6 has been done Barry, check the Squadron T-6 in action book for a T-6 on a central float!
;)  B)
dragon
Since you are already showing yourself as a target to JMNs....How about a floatplane:
ME-262
J7 (whatever it is) Shinden-Kai
Bearcat
Tigercat
If you are going out as a target, go big!
retro_seventies
aaaaahhhhhhhh seaplanes....
i'm not even remotely in the same league (barely the same planet) when it comes to modelling as you Barry, but by god, i love my seaplanes (what if, obviously).
you've seen the beaufighter seaplane (although not very beaufightery, it's definitely a bristol), you've seen the meteor seaplane, and i've justs been tinkering with a few more drawings this afternoon - let me dig them out and i'll post them...i don't think that you mentioned any of them as your upcoming projects, but you can sure as heck build them if you wish, chances are that i'll croak of old age before i build half the ideas that i have...
like the idea of a p-47 observation plane very much...taking the place of the kingfisher?
elmayerle
Just a thought, for the floatplane Bf109, use twin floats and strust similar to the ski conversion for the Bf109 where you tie in to the exisitng aircraft structure.  You could do the same for a "different" Spitfire floatplane.
--Jane Wagner and Lily Tomlin
There was a Bf109 floatplane - Me109W ? I think A Model do a kit
elmayerle
QuoteThere was a Bf109 floatplane - Me109W ? I think A Model do a kit
They do and it follows the drawing in the AJ Press book.  The thing is, I'm not totally convinced that that approach is the easiest way to do it.  The approach I suggested requires a minimum amount of extra structure, primarily just some beef-up on the the structure holding the MLG trunnions.  If you feel a need to stabilize the floats more, run a streamlined strut from each back to the tailwheel attach structure.
Martin H
And Adrian at Lonewulf does a cheaper resin conversion for the Italeri 109F kit Chris. got one on hanger queen row.  slowly getting there with it.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
TomZ
Be sure to name it the FR-2 SeaBolt as the FR-1 Seabolt already exists.  :rolleyes:
Look at : XFR-1 Seabolt
Tom
QuoteBe sure to name it the FR-2 SeaBolt as the FR-1 Seabolt already exists.  :rolleyes:
Tom
Ah, but mine is SeaBolt ™ ---note the capital "B"  (well, those JMN's do love details, right?!)   ;)
TomZ
Damn, I knew I should have got a patent application  :angry:
Tom
elmayerle
#12
Just a thought, JHM.  Take a look at what the same designers did in adding floats to a previous design of similar proportions, the Seversky  SEV-3:
For reference, here's the landplane version:
Edit: Images added by edit
Coooooooooooooooool, my mind's absolutely reeling now.
Very intriguing!    :wub:
Hunter Gatherer
IGNORANCE ALERT....[/size]
Guys... What's a JMN ?
IJ.
