avatar_Wardukw
Single engined Blackburn Buccaneer ....DONE!!
Started by Wardukw, October 16, 2024, 11:00:02 PM
But one TF-30 is only a tad more powerful than one Spey, unless you run it burner the whole time.
A Rolls Royce  BR 700-715C1-30   would give you over 21,000 lbs of thrust, but you'd have to play games with the timeline in your backstory.
Quote from: Rheged on October 24, 2024, 07:07:38 AMA Rolls Royce  BR 700-715C1-30   would give you over 21,000 lbs of thrust, but you'd have to play games with the timeline in your backstory.
Kits second rule 👌
That's Gentlmens rules are very handy pretty much all the time  ;D
Thanks to Kericks voice being stuck in the back of my head about the intakes and all the aircraft ive checked I've finally come up with a way to enlarge them ..ive widened the original intakes by 4mm . ;D
So now they'll still look like Buccaneer intakes but taller  :thumbsup:
Late the party on this build.. liking the thought direction. Even though I am a big Bucc fan and this is sort of heresy... I like it !!!!
Quote from: Wardukw on October 26, 2024, 11:15:10 AM
Kits second rule 👌
Looking forward to seeing it!
Quote from: buzzbomb on October 26, 2024, 02:55:47 PMLate the party on this build.. liking the thought direction. Even though I am a big Bucc fan and this is sort of heresy... I like it !!!!
Brian mate I'm becoming a fan of this beast ..the look of this plane has grown on me quiet alot and that's the main reason I've tried to keep this looking as much like a Buccaneer has I can ..minus its airbrake ..that I just couldn't find a place for it ..so it's a brake chute now .
Quote from: kerick on October 26, 2024, 05:15:25 PM
Kits second rule 👌
Me to Ken ...im really enjoying how this is turning out  ;D
Gives me an idea to kitbash with the Sea Vixen.
Quote from: Wardukw on October 26, 2024, 06:26:45 PM
Kits second rule 👌
I'm always willing to help out a friend!  :wacko:  :wacko:
Quote from: kerick on October 28, 2024, 07:05:13 AM
Kits second rule 👌
😆 🤣  damn right about that  ;D
The new intakes do look pretty good ..bigger for sure but still have the look of the Buccaneer  :thumbsup:
Quote from: Wardukw on October 28, 2024, 10:23:13 AM
Kits second rule 👌
If you don't post a pic it never happened.......
Quote from: kerick on October 28, 2024, 10:27:08 AM
Kits second rule 👌
If my internet speeds up abit then it's possible I'll post a update ...I had a wee mini disaster with the nose cone and I'm now reshaping it..well not reshaping..more rebuilding it ..I epoxied it last night so it's good to go now for sanding  :thumbsup:
Quote from: Wardukw on October 28, 2024, 10:36:45 AM
Kits second rule 👌
Sounds like it inadvertently impacted a nonmovable surface during a vertical acceleration.
Quote from: kerick on October 28, 2024, 10:40:48 AM
Kits second rule 👌
Nope 😄
It's very strange actually bud ...I used air rifle pellets in the nose cone as weights ..nothing new or strange about that...and I used this cheap nasty CA glue to make say put ..nothing new or strange there either..done that many times too .
What I noticed was a dent in plastic which I thought was weird and when I pushed it ..it was very soft ...some how the CA was softening the plastic..it's never done that before..so I cut it out and the more I cut the less nose cone was there 😅
Weird that huh? 🤔 😅
So Tamiya epoxy putty has been doing it's job..so far it's going well 👌
Quote from: Wardukw on October 28, 2024, 04:40:59 PM
Kits second rule 👌
Nope 😄
Weird that huh? 🤔 😅
I had that happen with lead shot and CA. But only one time out of many. Weird.
Quote from: kerick on October 28, 2024, 06:08:22 PM
Kits second rule 👌
Nope 😄
Weird that huh? 🤔 😅
This has me thinking mate ..im wondering if it something to do with that plastic Airfix use.
I'm wondering this because I've done this many times with brands like Monogram.  Revell..Hasegawa and so on but not Airfix..im pretty certain I've never built a 48th scale Airfix kit before..before this one anyway also this is 30yrs old too and I did notice how soft this plastic is.
So that got the thinking going.
