avatar_zenrat
Korsaari. Finished pics pg 13.
Started by zenrat, November 02, 2024, 03:54:53 AM
Fingers crossed here. I was quite taken with the original finish. The decals are ace.
Personally, I have had mixed results from the hairspray distemper method.
Nail this and it will be fantastic. :thumbsup:
Quote from: buzzbomb on January 16, 2025, 03:31:03 AMFingers crossed here. I was quite taken with the original finish. The decals are ace.
My problem is knowing when to stop scrubbing.  I usually end up taking off more than I intended.
I'm at work all day tomorrow so i'll have at it with the toothbrush on Satyrday.
As was I  :thumbsup:
Quote from: zenrat on January 16, 2025, 03:48:33 AMI'm at work all day tomorrow so i'll have at it with the toothbrush on Satyrday.
I'll have money that's not miss-spelt  :wacko:  ;)
Day of the Satyr.  It's a more appropriate spelling.
So i had a scrubbing session.
Polar Corsair WIP 19-01-25 by Fred Maillardet, on Flickr
I stopped because I thought I had gone too far and removed too much white.  But looking at the pic I think I didn't remove enough.
Which probly means it's just about right.
Oh and both small support skis had to have connections reattached after this.  I've lost count of how many times i've had to re-glue them.
ericr
very impressive scrubbing !
That camo looks really good. What paint did you use for the white? Enamel or acrylic? I'd say it worked really well.
Quote from: zenrat on January 19, 2025, 01:46:10 AMI stopped because I thought I had gone too far and removed too much white.  But looking at the pic I think I didn't remove enough.
Agree, you can always remove more later. Or not...  ;)
Looks good.  :thumbsup:
Thanks folks.
Quote from: kerick on January 19, 2025, 11:04:51 AMThat camo looks really good. What paint did you use for the white? Enamel or acrylic? I'd say it worked really well.
The camo is Vallejo acrylic which I sealed with Glass Coat Gauzy Agent (other self levelling floor polishes are available).
I then gave it a coat of Hairspray.
Over that two coats of Vallejo acrylic white (24 hours apart).
I allowed it to dry for another 48 hours (probly over the top) and then rubbed gently (more stroking really) with wet fingers,  As the water soaks through the paint the hairspray lets go and the paint comes off.  It might be necessary to scrub to start with but once the water can get under the edge of the paint then it comes off very easilly.  I ran a toothpick around the control surfaces.
As the underlying paint showed through very glossy I today coated the whole upper surface with a diluted coat of Vallejo Acrylic Matt Clear to remove the shine.
Its nearly done.  I'm onto the fiddley bits now.
This I'm waiting to see 👀  ;D
Yep, looking very good indeed!  :thumbsup:  :thumbsup:
Thanks blokes.
The pilot is in place.
Prop is painted.
Exhaust in place.
Radio mast scratched up and attached.
Panel gaps washed.
And i'm toying with a pair of small bombs I may install.
Quote from: zenrat on January 25, 2025, 01:57:14 AMAnd i'm toying with a pair of small bombs I may install.
Shaped like Christmas Crackers? ;)
