avatar_killnoizer
1:35 - Sdkfz.234 Hovercraft / Landspeeder
Started by killnoizer, November 03, 2024, 09:19:29 AM
killnoizer
First tryouts with White and Rust , not really good ,  i have to do more ... any suggestion for me ?
This is white from BELTON and dry paint with Vallejo . Coated with MARABU clear mat.
They don't look too bad depending on the look you're after, I guess streaks.  Try thinning your pigments a bit, put a few drops of thinners next to your pigments on a palette. Draw the thinners into them a little at a time, testing on your palette.
Vallejo have a how-to video:
https://youtu.be/16sd_QzQFXs?si=5KxrPJYb7TNbj15K
I'm not familiar with Vallejo's but I've used Humbrol's weathering powders with some success.  They have some more in depth videos:
https://youtube.com/playlist?list=PL43gvX1AmlLYyQxhzqE4fArGdtbsSXZOV&si=BtrvvkVemZS25hty
killnoizer
#32
Thank you very much for your suggest, but there are no pigments used so far... But Mrs. K should have some in her stash, i will have a look!
Today my local dealer was in business, so i could get the basic grey from BELTON and push it all over .
Where that putty is visible i will try some bigger parts of rust and damage, so these places are prepared with that for the dry paint weathering , i hope
It rather looks like a submarine?  ;D
killnoizer
It is a LASER RAY GUN not a periscop  :wacko:
loupgarou
Quote from: Dizzyfugu on November 16, 2024, 08:23:14 AMIt rather looks like a submarine?  ;D
The image I have of an hovercraft is quite different. Where are the skirts?
perttime
Quote from: loupgarou on November 16, 2024, 10:52:00 AMThe image I have of an hovercraft is quite different. Where are the skirts?
It uses a technology not currently revealed to the public. If I told you any details, I'd have to shoot you  :wacko:
killnoizer
#37
Quote from: perttime on November 16, 2024, 11:21:53 AM
I have modified the title of the thread,  it was my mistake 😱 to call it a hovercraft, just in cause of the way it will move...
I'm searching for the correct name in german.
It says hovercraft not air cushion vehicle.  It's a craft that hovers.  So hovercraft is correct.   :thumbsup:
loupgarou
Quote from: zenrat on November 17, 2024, 03:56:23 AMIt says hovercraft not air cushion vehicle.  It's a craft that hovers.  So hovercraft is correct.   :thumbsup:
Of course, you're right. But my mind is still thinking of the Airfix SR-N 4 as a proper hovercraft.  ;)
killnoizer
Vielleicht besser
SCHWEBE KRAFT DIVISION in Deutsch 😬
The spots of putty really puzzled me for a while. I keep waiting to see them sanded off. Now I understand what you were thinking of. Right now it looks like those spots on steel where the corrosion has worked its way under the paint and bubbled it up. Very cool.
