avatar_frank2056
1/72 Victory (Победа) 357 Hawk
Started by frank2056, November 12, 2024, 07:29:52 PM
Quote from: Rick Lowe on November 14, 2024, 08:08:53 PMIs this the right time to mention the craft now looks like it has a ball-gag? :o  :o
Or even the right forum?? :angel:
I guess I wasn't the only one to think of Pulp Fiction when I saw it!
frank2056
I printed a new radar dome for the 357 Hawk (NATO reporting name Ballgag) because the old one was just a little too wide for the grill frame and I was afraid that it would crack it. I'm currently smoothing out the ABS.
Don't know what kind of bomber this would be, though.
Quote from: frank2056 on November 16, 2024, 12:41:10 PM357 Hawk (NATO reporting name Ballgag)
;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:
Quote from: Old Wombat on November 14, 2024, 06:41:06 AM
Quote from: zenrat on November 14, 2024, 01:51:52 AM
Quote from: Mossie on November 13, 2024, 04:02:04 AM
Quote from: zenrat on November 13, 2024, 02:57:05 AMHow tall is that grille in the front?  It'd look great on a Hot Rod model especially as it'd confuse the heck out of onlookers trying to work out what car it came from.
 There's a nice clear pic of it on Super Hobby with a ruler, seems to be around 2.5cm high by 1.8cm wide. I'm sure Frank can give you more accurate measurements.
Thanks mate.  That's a bit small for a 1/25 Rod.
Actually, it looks to be closer to 35mm high by 30mm wide (using a ruler held up to the screen to get the measurements & holding them up to the scale down the bottom of the image).
Thanks.  A better size, but an expensive way to get a radiator grille for a model car.
Quote from: zenrat on November 17, 2024, 03:59:06 AMThanks.  A better size, but an expensive way to get a radiator grille for a model car.
Could you use the rest of the Victory Hawk for another project with a new front end grafted on? It might justify the cost, although it's not a cheap kit.
frank2056
#21
Finished this last night. What's funny is that I liked the 3D render, but the 3D physical object... not so much. Ugly and unrealistic.
I painted an anti-glare panel on the nose in olive drab. I added a pitot tube on the front windscreen, an intake for the jet and an antenna at the rear:
It's a pretty big vehicle, compared to the 1/72 figure. 2411 is the year and month I finished this:
The aluminum is mostly Mig Atom aluminum, with some areas with a mix of Atom aluminum and steel. Some Tamiya panel line accent color helped a bit. The end bits on the pods are from the AMT 1/200 rocket set:
Big radar:
A bit late, but for another version, maybe a row of wheels along the bottom of the outriggers, like the Arado 232 or Messerschmitt 323 Gigant could work?
And yes, it's come up nicely. :thumbsup:
