avatar_The Rat
Jet Propelled Flying N.A.A.F.I.
Started by The Rat, November 14, 2024, 06:58:36 PM
You've made a good job of the Belvedere canopy!
I've never seen one with that good a fit to the two halves.  :thumbsup:
Quote from: PR19_Kit on December 02, 2024, 06:26:55 AMYou've made a good job of the Belvedere canopy!
The trick is to ignore the mismatch at the ends of the seam, and just deal with the fact that it will need some sanding/filing/scraping/swearing in order to mate up to the fuselage. It will also need sanding down along the forward bulge, and then polishing. The hardest part to that is doing it without cracking the seam apart and needing to reglue it. Ask me how I know...  ;D
A fair bit of touch-up to do, mostly around the canopy, but it's coming together.
Ohhhh that's so nice  <_<  <_<
Bloody nice Ratty 👌 👍
steelpillow
Like this one. Do the clientele all troop in one and and out the other, or is there a serving hatch in the side.
Eccles: "How do I open the door?"
Bluebottle: "You turn the knob on your side."
Eccles (pauses to check): "I haven't got a knob on my side!"
Cheers.
 ;D  ;D
The side door will be open, might make a tea urn to sit on the edge.
Quote from: steelpillow on December 12, 2024, 12:00:18 AMLike this one. Do the clientele all troop in one and and out the other, or is there a serving hatch in the side.
 ;D  ;D
 ;D
Coming along well.  :thumbsup:
Accidental Loggie
Quote from: The Rat on December 12, 2024, 03:03:50 AM;D  ;D
As long as no-one falls in the (hot) water, all should be well!
Converte et subvertere
Quote from: Accidental Loggie on December 13, 2024, 08:15:13 AM
"Heeee's fallen in the waterrrr!" I think that was Bluebottle.  ;D
I should, at this juncture, explain the use of the word 'flying' instead of 'guided,' as in the title of the Goon Show episode. I reasoned (as best my feeble brain will allow) that 'guided' was more in keeping with a missile, and that 'flying' would be much more suitable with a helicopter.
As to the font I will be using, a perusal of the interwebbies makes it rather easy, as there seems to have been as many fonts as there were vehicles, with little or no attempt at a standard. 'Dubai' seems to be close to some pictures I've seen, and will probably be my choice.
