avatar_The Rat
Avro Vandal
Started by The Rat, November 30, 2024, 11:41:56 PM
The manoeuvrability of the Avro Vulcan was excellent, but it also looked like it could be pushed much further toward 'fighter' status. After careful study, it was determined that a canard configuration would allow for even faster movement in the pitch axis, allowing for a faster turnaround after a Blue Steel delivery. A B.2 was modified with a 12'5" fuselage extension, and canards fitted below the flight deck area. Tests showed impressive performance, and 25 new aircraft were ordered. The modification was considered enough to confer a new name, and the Avro Vandal was born, with a two syllable name honouring it's predecessor.
The Kit
CyberHobby 1/200th scale offering. Not a bad kit, but the gaps are a little large. Cockpit detail is unecessary in this scale, but they include a sparse one anyway. There is a crew ladder and ground vehicle as options, and provision for a wheels up build. Recommended for a quick build, so long as you don't try to 'Viggenise' it!
Terrific looker Ratty  :thumbsup:
Glenn Gilbertson
That looks really good! :thumbsup:
'Elegant' is not a word I'd have associated with the Vulcan, but the fuselage stretch makes the Vandal rather elegant.
That looks good - nice one! :thumbsup:
The canards don't work 'cause the vandals took the handles......
Looks like a long necked Vulcan goose to me lol.
Very nice Ratty !
Quote from: Captain Canada on December 01, 2024, 08:22:47 AMThe canards don't work 'cause the vandals took the handles......
Very nice Ratty !
 ;D  ;D
loupgarou
Thank you all, gentlemen! I had it on the table at SMW, but without the gear, because I was certain it would get broken off after a succession of baggage handlers had their way with my luggage. Nice to finally give her some legs.
I've always thought the Vulcan looked a bit as if she was hunching her shoulders, and needed a longer 'neck'. Nice to see it in plastic.
I also think that the Vandal looks better than the original Vulcan. :thumbsup:
