avatar_The Rat
Flying N.A.A.F.I. finished!
Started by The Rat, December 26, 2024, 05:29:30 PM
When significant changes were made to the Bristol Belvedere to bring it to service status, Bristol was left with two airframes to play with. At home one evening after a long day at work, a member of management was listening to The Goon Show on the BBC, specifically an episode entitled The Jet-Propelled Guided N.A.A.F.I., and a thought struck him; what about a flying N.A.A.F.I. for the use of troops in the field? It wasn't guided, like a missile, but it did have two turbine engines, so instead the project was named The Jet-Propelled Flying N.A.A.F.I. A suitable large tea urn was manufactured to serve the thirsty soldiers, who soon christened the helicopter the '10 Ton Teapot.'  A rather garish but patriotic paint scheme made it readily identifiable from a distance, notifying everyone in sight that a 'cuppa char and a wad' were soon available.
The kit
Airfix obviously, recently re-released without any improvement other than a better decal sheet. It represents the prototypes, the most externally notable change being the rear empennage. Fit is passable, except for the forward transparency, which is atrocious. Wheels have centre holes that are far too large for the axles, so I found some replacements from the spares bin. After assembling the major bits, one is left with the final frustration; attaching the rotors. The kit design requires that if you want the rotors to turn, which is useful for storage, the hubs must be installed before the fuselage is joined. It would be much easier to allow the blades to be attached to the hubs before attaching the whole assembly to the kit, but it can't be done here. Another fault is the lack of any interior detail other than the flight deck, so if you want the side door open you may wish to at least install some sort of floor.
But she's done, I like it, and present it for your perusal.
:thumbsup:  :thumbsup:
*Slurp, Chomp*
"I don't know who you are, Sir, but you've done me a Power of Good."
That's REALLY good Ratty, even the rivets.  ;D
Superb!  Well worthy of a Whiffie nomination.
