avatar_seadude
Mini "American" Landkreuzer
Started by seadude, December 29, 2024, 09:30:14 AM
seadude
I've got a whole bunch of spare 1/350 scale 16" gun turrets from old TAMIYA 1/350 scale Missouri and New Jersey battleship kits. Sample pic below.
The entire thing is about 2 inches wide x 3 inches long and is about 3/8 inch high.
Just as the Germans had proposed the Landkreuzer P1000 super heavy tank back in WW2, I had the thought of what if the Americans had countered the Germans with their own version of an Americanized Landkreuzer?
But what size tank chassis can I put a 1/350 scale gun turret on? What would work? 1/48? 1/72? 1/35? or something else?
perttime
2 inches wide.... at 1/72 it would be about 12 foot wide in real world. A little wider than a Tiger or Panther. Much wider than a Sherman. At 1/48, it would be 8 foot: almost as wide as a Sherman.
frank2056
In 1/350, the original Landkreuzer tracks would be about 10.3mm (0.40") wide, each. TheT-34 tracks were around 500mm-510mm wide, so you could use 1/48 T-34 tracks, which would be about 10mm - the right size in 1/350.
Rather than finding a hull and tracks that would fit, why don't you design the superstructure to fit the turrets, give it a supersized American esthetic, then look for a lower hull and tracks that would fit? You also try combining the tracks from several 1/144 tanks (which are relatively cheep) and would be slightly more "realistic" - fixing a thrown track, 3.5m wide, would be quite a production and would put the vehicle out of operation for most of a day.
Quote from: frank2056 on December 29, 2024, 10:50:06 AMIn 1/350, the original Landkreuzer tracks would be about 10.3mm (0.40") wide, each. TheT-34 tracks were around 500mm-510mm wide, so you could use 1/48 T-34 tracks, which would be about 10mm - the right size in 1/350.
Fixing a single, continuous track on a thing
like the Landkreuzer would probably take more like a week than a day.
;D
What about an American Monitor?
Something to give (a lot of) fire support to the Brown Water Navy...  :o
Or throw it onto something Cruiser-sized; a US take on the so-called Pocket Battleship.
I have a feeling that a 1/35 Churchill tank might suit what you're after.
The hull might (will) need a bit of re-working but the numerous small road wheels would work & the track is, for the scale, fairly narrow.
I don't have instant access to my Mk.VII right now, for getting accurate measurements, but I'm fairly sure it'd do the trick.
Probably the easiest way to rework the hull would be to use the existing track units and replace the middle bit entirely,
You'd be able to scab details from the parts onto it again, but placing them where you wanted them and not having to cover over those that were inconveniently situated.
According to this article the profile of the P.1000 is not how the actual project looked. It's based on midunderstanding of written descriptions. One feature that all of Grote's concepts had in common, going back to the early 1930s, was three runs of track on each side of the vehicle. Each individual track was 1.2 meters wide.
Projekt P.1000
Photo of mockup of first configuration, October 1942, 2.5 meter diameter road wheels:
Second configuration, December 1942, larger number of smaller road wheels:
seadude
Quote from: jcf on December 30, 2024, 10:03:50 AMAccording to this article the profile of the P.1000 is not how the actual project looked. It's based on midunderstanding of written descriptions. One feature that all of Grote's concepts had in common, going back to the early 1930s, was three runs of track on each side of the vehicle. Each individual track was 1.2 meters wide.
Projekt P.1000
I'm not sure, but I think both of those pics are in this book (Below) that I borrowed and read from a friend. In fact, I still need to buy that book sometime.
I really do see those as early concepts for Bolos. Though with much less in the way of armaments...
You would need a tower with a bridge to pilot the thing and direct fire. Nice fantasy but to think the Germans actually wasted time and resources on these sort of things is astounding.
Though it stopped them from building other things that worked, and extending the Unpleasantness.
True
Much like their rocket program. It wasted their resources and didn't really change the course of the war.
I love the writer's comment on the October 1942 configuration:
"The arrangement really looked almost childlike in the idea of cramming as many guns or turrets onto a hull as possible, seemingly with little thought as to how these might actually be used."
;D ;D :wacko:
