avatar_TomZ
1/35 K-Wagen
Started by TomZ, January 11, 2025, 11:04:53 AM
WHAAAAT?  :o
You can actually BUY separate rivets? Whatever next..................  :-\
You can also buy resin-cast raised panel lines. Apparently there's a market for that...  :rolleyes:
TomZ
Quote from: Dizzyfugu on January 21, 2025, 04:42:56 AMYou can also buy resin-cast raised panel lines. Apparently there's a market for that...  :rolleyes:
Got this for the panel lines. Should suffice.....
TomZ
I am a fan of WWI armour.  Good to see the craziness that was the K-Wagen taking shape. :thumbsup:
A potential source for rivets is a water filter. There are hundreds of tiny balls of several different but consistent sizes.  You drill a slight depression, pop a tiny amount of CA on and drop the ball into it. Works well on builds I've seen it on.
Simple white glue tips with a toothpick are another convenient solution.
Quote from: TomZ on January 21, 2025, 04:55:09 AMGot this for the panel lines. Should suffice.....
TomZ
Dug up out of the trash heap from Matchbox?
Quote from: PR19_Kit on January 21, 2025, 04:07:44 AMWHAAAAT?  :o
And there's 4 or 5 producers inc. Eduard etc  :angel:
frank2056
Including Meng, which makes several plastic bolt types and sizes that you have to (carefully) cut off of a plastic backing. They're very handy. Tichy Train Group has been making bolts and bolt heads since the beginning of time (or thereabouts). Archer used to make resin rivet decals, but companies like Quinta using raised detail color printers have taken over.
I used Archer's car bonnet louvres for my brother's Caterham model a few years ago, and they were superb, worked a treat.
Quote from: PR19_Kit on January 22, 2025, 09:49:55 AMI used Archer's car bonnet louvres for my brother's Caterham model a few years ago, and they were superb, worked a treat.
Have ya seen the resin weld beads Kit ? ...never used em but I'm thinking of giving em a try 🤔 😏
Another option for rivets is  Tichy Train  rivets, used on Model Railway builds. Individual rivets of various sizes give you a lot of options
used them extensively on the Mk V** Conversion i needed for the "Testing the Bailey Bridge" Diorama
Quote from: buzzbomb on January 22, 2025, 01:47:35 PMAnother option for rivets is  Tichy Train  rivets, used on Model Railway builds. Individual rivets of various sizes give you a lot of options
Very very nice Buzzy mate 👌 😉
More of this will need to be seen bud 😃
Jakko
I make rivets with a punch-and-die set and "domed" (actually conical) punches. You can buy a complete set with those, including a die, but if you already have a punch-and-die set, buying some separate/replacement "domed" punches is much cheaper. Or, if you only need the occasional domed rivet, look through your modelling drill bits to see if any of them have a conical end to the shank, and use that in the die. Be careful not to break the bit, though, so it's probably best to use worn-out or already-broken bits for this.
As an added tip: before making domed rivets like this, colour one side of the plastic card you use with a marking pen. That way, you can tell easily which side should go outward — if you don't, it can be very hard to see which way round the rivet is when you want to stick it to the model.
