Hercules twin
Started by Beermonster58, January 20, 2025, 10:41:35 AM
Quote from: Rick Lowe on January 23, 2025, 08:28:10 PM
Quote from: Gondor on January 23, 2025, 01:21:28 PMYou could always mount them YC-14 style, partly in the wing, but the upper surface.
Beat me to it!  :thumbsup:
Quote from: McColm on January 23, 2025, 07:55:01 PMHeller 1/72 C-160 model kit
The trick would be to find one here - forget about the 'too expensive thing', the 'unobtanium thing' trumps* it...
*apologies for the terminology...  :banghead:
I did look at some 72nd airliner prices...yeah I don't think so ...anything with 4 engines was over $120 nz and twin engined wasn't a hell of alot different.
As to the turbofan engines, why not use the ones from the Lockheed S-3 Viking? Two secondhand kits should do the trick .
Quote from: McColm on January 24, 2025, 06:02:37 AMAs to the turbofan engines, why not use the ones from the Lockheed S-3 Viking? Two secondhand kits should do the trick .
Not a chance finding em here Mac ...it's like the hens teeth deal ..if ya found one it's very unlikely to find two but damn dude those might have worked..with mods of course  ;D  ;)
Quote from: Wardukw on January 24, 2025, 10:03:33 AM
So you don't mind if I use them on a C-130 whiff?
Quote from: McColm on January 24, 2025, 11:23:13 AM
Fexking go for it Mac  ;D
The more the merrier..im still smacking ideas around but it's looking more likely that one of my 48th A-10s is gonna loose it's engines  :wacko:
Quote from: Wardukw on January 24, 2025, 08:28:35 PMit's looking more likely that one of my 48th A-10s is gonna loose it's engines
There was an idea I saw where someone suggested cutting an A-10 behind the wing, putting a pusher turboprop engine back there with a top-mounted radiator scoop and you have a nifty light attack job.
Lose the 30mm and substitute a brace of something similar but single-barreled and go hunting. :thumbsup:
Something I still plan, as and when I can excavate my A-10... :banghead:
