Hercules twin
Started by Beermonster58, January 20, 2025, 10:41:35 AM
Beermonster58
Quote from: Wardukw on February 05, 2025, 11:33:13 AM
Quote from: Beermonster58 on February 05, 2025, 02:17:29 AM
Quote from: Wardukw on January 31, 2025, 05:57:14 PM
Quote from: Rick Lowe on January 25, 2025, 05:08:47 PM
Quote from: Wardukw on January 24, 2025, 08:28:35 PMit's looking more likely that one of my 48th A-10s is gonna loose it's engines
There was an idea I saw where someone suggested cutting an A-10 behind the wing, putting a pusher turboprop engine back there with a top-mounted radiator scoop and you have a nifty light attack job.
Lose the 30mm and substitute a brace of something similar but single-barreled and go hunting. :thumbsup:
Something I still plan, as and when I can excavate my A-10... :banghead:
I'm having a similar idea for a A-10 turbo prop ground attack aircraft but in this very strange scale called 72nd scale  :o  :o
Now if I had a 48th C-130 to play with I'd do a 48th one but woe is me on that front 😆
Quote from: Beermonster58 on January 31, 2025, 01:12:10 AMDon't know what this "1/48" thing is about 😉😂. However, I did once consider fitting a pair of CFM - 56 hairdryers to a true scale C-130. They were donated by the Airfix ( Ex Heller) E-3 kit which had options for two engines.
The pylons were fairly short and, ground clearance looked OK but, it never came about because I ended up building the E-3 as the RAF version anyway
Monster mate I do understand your frustration with this scale thingy..I to have this issue with this 72nd scale I read chaps talking about and they say it's the one true scale...so I've no idea what that's about..it's all very strange actually bud 😳 😀 😉
Don't worry about it. You will see the light. God will guide you to the true path! ;)  ;D . I find 1/72 the most practical scale as, even very large aircraft (I have a Revell 1/72 B-36) are doable. The B-36 incidentally finish up in RAF Dark green/ Dark Earth/ Black because I dislike natural metal finishes almost as much as I dislike boring , grey jets...! ;D
Oh the gods did guide me monster mate ..it's called 1/35th scale 😆 🤣
I know the B-36. ..had two em over the decades and bloody near had another one a wee while ago but common sense got the better of me  ;D
Had the B-52 aswell and id have both again if I had the space 🙃
Dude I really do like your paint colour choice for your 36 ...that would look so different and im'a liking that muchly 😃
👍Actually, I dont mind 1/35 because the vehicles in that scale dont take up much room👆😊.
Thank you for the comment on the B-36. I had considered other options, either the gorgeous "Royal Aircraft Establishment" raspberry ripple" scheme or, the later Bomber Command Grey/Green/PRU Blue (looks nice with Suez invasion stripes).
I might still change my mind...... 😂
Beermonster58
Quote from: kerick on February 05, 2025, 02:55:27 PMSEA scheme on a B-36!
Actually, that WOULD look nice. Not too dissimilar to the RAF scheme AND, with black undersides too👍😊
Beermonster58
Quote from: Rick Lowe on February 05, 2025, 05:35:38 PM
Most things look good in SEA cam... :thumbsup:
Maybe a Vulcan with a HSAB under each wing?
My B-36 is going to be backdated to an A (no burnin' just the six turnin'), RAAF, in Anti-Flash White.
Quote from: zenrat on February 06, 2025, 01:55:16 AMMy B-36 is going to be backdated to an A (no burnin' just the six turnin'), RAAF, in Anti-Flash White.
That sounds cool.  :thumbsup:
Plenty of scope for dirtying her down, too...
And the four burnin' can be used for all sorts of other Whiffs too.  :thumbsup:
Quote from: PR19_Kit on February 06, 2025, 02:57:14 AMAnd the four burnin' can be used for all sorts of other Whiffs too.  :thumbsup:
Beermonster58
That's an idea. A re engined Arado AR-E555 perhaps 🤔😊
[/quote]
[/quote]
Dude ..mind change..do it!!!
A B-36 in that scheme would look amazing and with invasion stripes 😍
The command gray and green would look great and we all know Kits feelings about PRU Blue 😆 🤣
35th scale is great as long as you don't have the disease I have...SPG's and large tanks and tank transporters  :o  ;D
Space becomes a issue then  :wacko:
Well the bug has bit ...bitten hard ..so I've already hacked this thing up a wee bit 😳
Ya know ..getting a feel for how I want the end result to look .
There's one change to my original plan..this will still only have two engines..but now turbo proped with two massive 6 bladed propellers  ;)
Beermonster58
[/quote]
[/quote]
You know, I'm now definitely leaning towards the Suez scheme........! ;D
Quote from: Wardukw on February 06, 2025, 10:59:22 AMThank you for the comment on the B-36. I had considered other options, either the gorgeous "Royal Aircraft Establishment" raspberry ripple" scheme or, the later Bomber Command Grey/Green/PRU Blue (looks nice with Suez invasion stripes).
How about a PR-36 in RAF service but in overall PR Pink ?  ;)
IS there that much PR Pink paint in the world?  :o
Quote from: PR19_Kit on February 19, 2025, 06:28:42 AMIS there that much PR Pink paint in the world?  :o
I've stocked up on it so I can corner the market. Eat your heart out Bitcoin  :wacko:  ;)
