avatar_Wardukw
Hercules twin build thread
Started by Wardukw, February 20, 2025, 01:31:22 AM
Quote from: zenrat on February 27, 2025, 04:03:03 AMHe was chased away and when he got to come back they had never been there.
You don't say?  ;)
Those long tubes were just, ahhh, spilled cargo! Yeah, that's it, that's the ticket!
Quote from: PR19_Kit on February 26, 2025, 05:28:03 AM
Quote from: zenrat on February 26, 2025, 03:38:12 AMBetter view on this one.
Doesn't look like it worked too well on this occasion though.................:(
Follow the link and read the article.  It ended up like that not from enemy action but because of incompetence.
I know the photographer.  He told me that when he got there the weapons were visible (it's an AC-130).  He was chased away and when he got to come back they had never been there.
Oh I'm well aware that's not battle damage...battle damage has this habit of setting fire to things and the carnage this poor bird went through is too clean ..ripped and blown apart shows different results in the damage.
Not surprised your mate got told to bugger off ..very likely live ammo on board ...but also the techy stuff ..remove all weapons ..ammo and maybe some sensors..not sure about that part but the ammo definitely..105mm rds exploding will ruin everybody's day 😆
Saw this just now... and looking forward for the rest!  :thumbsup:  :thumbsup:
Quote from: DogfighterZen on February 27, 2025, 03:15:36 PMSaw this just now... and looking forward for the rest!  :thumbsup:  :thumbsup:
Cheers Rui 😊
More work on this today ...a bit more PSR..a wee alteration to this and abit of cutting to there and I'm happy with the results..you guys will see 👀 😀
I'm not saying much as I'm won't be totally happy until the PSR is done ..if I'm 100% happy then I'll speak up  :thumbsup:
The wings are on  :thumbsup:
The left wing went on without a hassle..glued ..reinforced to remove any chance of drooping..so far so good.
The right wing tho ...the mother humper wouldn't seat flat against the engine pod ..even tho the mounts are exactly the same either side ...I checked ..more than once  :banghead:
So I had to rip out the brass wire pins and redrill the 1mm holes to 2mm and them used some fiberglass rod and notched the back so the wing would move at the back for adjustment.
CA nailed it cause of the glue from left behind from the first attempt...now PSR has also taken place.
Tomorrow I'll probably sand it down and very likely PSR some more  ;D
Progress has been made Gentlemens  ;D
DSCF4942 by Phill Harrison, on Flickr
DSCF4943 by Phill Harrison, on Flickr
DSCF4944 by Phill Harrison, on Flickr
Shes now primed in black and awaiting the human to made his arse up on the paint scheme  :banghead:
Some solid progress. Terrific build  :thumbsup:  :thumbsup:
Oh yeah, that's looking really, REALLY good!  :thumbsup:
Love the winglets! Nice touch.
This really looks great!
Still needs lots of antennas.
Cheers guys 😁😁
Have you ever started a build with a vision in mind and it's turned out better than you thought?
This is one of those builds for me ..normally for me it's not the result at the end which my mind saw ..it's just not right or something just doesn't gell ..this one isn't one of those  :thumbsup:
Ken mate, those winglets were a last minute idea and damn they worked out well ..knew I'd have a use for a 1/144 scale mig 23 😊
Now ya mention it I knew something was missing..bloody aerials..this won't be fun ..pretty sure I don't have anything that small...48th is just to big ..maybe I've got really small 48th ones ..I shall investigate 🔎 😄
Just cut some from thin strip. I've used the PS food packages which is very thin.
Quote from: kerick on March 05, 2025, 07:16:02 AMLove the winglets! Nice touch.
Mate the antennas are going to be sorted..I found amongst the stash a plane I knew..well thought I had ...and have now found..a 72nd Hasegawa su27 ..it's a strange one and I think a mate gave it to when a brought a huge pile of kits of him couple of yrs back ...it's got 2 full sets of wheels..2 white metal front landing gear  and a lot of missiles ...which have given up some of the fins and when turned upside down..antennas 😆  :thumbsup:
