G
Fairey Thunderbolt F-1(?)
Started by Geoff_B, July 06, 2005, 01:52:28 PM
Camo with a load of iron bombs !
Just like the old Phantoms.......too cool !
Geoff_B
Ah well the FD-3 is finished, unfortunately surface blemishes on this scratch build meant after primming meant that the original ADV grey option would be a bit impractical so went with the more traditional 70's Phantom style scheme.
She is carrying 141 Sqdn markings as this was former Javelin Air Defence unit , so i didn't clash with the lightning history. She is armed with a Belly tank, Blue Dolphin under the Intakes (Blue dolphin being a semi active radar seeker version of Red Top), Red Hebe long range radar guided missiles and Red top IR heat seekers on the outer pylons.
The ADV version in 145 sqn markings will have to await a resin copy.
Cheers
Geoff
I think I just had a religious experience.  :wub:
You da man!  :cheers:
Just a great model....
Guys: Can you imagine one of these puppies doing a fast & lo pass at the (much missed) Finningly or (even more missed) Mildenhall show.
Ahhhh well.
I H-G
Martin H
QuoteGuys: Can you imagine one of these puppies doing a fast & lo pass at the (much missed) Finningly or (even more missed) Mildenhall show.
Ahhhh well.
Now that would be a sight to behold
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Ollie
Brilliant ! and better in the flesh then in the photo - as is Nev's Korean F.20
Heh, those squadron markings had us all scratching our heads at Donny  :D
Brilliant as usual Thorvic, I simply love the FD3 (Thunder). when are the resin kits gonna be available??
Aircav
Cool Geoff, Cool  :D  :D  :D  :D  :D
Sir Sydney Camm
Vertical Airscrew SIG Leader
Mike Wren
Martin H
Quotewhen are the resin kits gonna be available??
In simple terms Lance. Your guess is as good as ours lol
Unfortunately,
Absolutely believable!!
:wub:  :wub:  :wub:
Geoff_B
Well we try to make them believable or at least plausible. As for the resin one you'll have to pester Joe Cherrie as that was his job ;). I just decided to try another to check out a different buils appraoch and rectify some of the gaffs with the original one i did following access to better data.
Another factor was to try out a suitable British warload. The Red Tops and Blue Dolphin (radar guided red top) are from the Frog Sea Vixen, with the Blue dolphin being a red top with a pointed nose cone. The Red Hebe is based upon a 1/48 Sparrow with the fins replaced.
Cheers
G B)
Archibald
Hello... It's to make a Delta III, particularly the air intakes :( . How did you do that? enterely from scratch or slaughtering a kit as basis?
