avatar_rallymodeller
Trainers With Teeth and COIN Group Build
Started by rallymodeller, September 04, 2005, 10:26:10 AM
Should we merge the "Trainers With Teeth" and "COIN" Group Builds?
YES - Merge
22 (95.7%)
NO - Do Not Merge
1 (4.3%)
Total Members Voted: 22
Voting closed: August 14, 2008, 03:47:21 AM
And something that evolved from a trainer to be an attack plane, for instance Hawk -----> Hawk-200 ?
I am particularly interested in the same evolution from an AlphaJet.
:party:
if i had a good canopy, i would scratchbuild an armed version of my SABCA ST-1A (see junkyard GB)
alfajets and SF260 have combat versions to (see portugese single-seat Ajets).
maybe armed airfix Piper Arrows or SA Bulldogs  :thumbsup:
Jschmus
It's kind of the upper end of arming trainers, but this was posted to Starship Modeler a few years back.
http://www.starshipmodeler.org/gallery7/rd_strikegator.htm
To properly qualify for the build, you'd have to call it an "AT-43", but you get the idea.
Quote from: Ian the Hunter-Gatherer on June 04, 2008, 11:46:39 AM
As you can see, this really (another) aviation themed Group Build idea. I'd be happy to 'mod' with somebody else (JHM, I'm looking at you !) it if it ever 'took-off' (pun intended). So over to you guys, let's read your thoughts and ideas..... it wont get onto the calender until 2009 at the earlies so lots and lots of time.
Fixed that for you mate ;)
AeroplaneDriver
I'd be very interested in this one.  Since I've taught in Dash 8 and 737 sims are they open for entry?   ;D
If not I guess I'll have to do my RAF Britnam Strikemaster...or an AT-45...or a Cessna 172 with machine guns for after the asteroid hits and civilization collapses...
Renault Clio with L-plates and a pintle GPMG out the sunroof? ;D
Quote from: pyro-manic on June 12, 2008, 02:31:08 PM
Honda CG-125 with L-plates and a bazooka each side?  ;D ;D
AeroplaneDriver
Just a GPMG?  I'd say go all out with a Vulcan mount!!   :thumbsup:
Don't forget the "Student Driver" placards.
Quote from: philp on June 12, 2008, 11:12:08 PM
You mean 'L' plates ???
In the US, we spell it out for the other drivers.
I assume an L plate is similar.
Not so much a trainer, but not far off being one:
Those are AIM-7 Sparrow missiles!  Whenever one thinks some of our creations look outlandish, just remember the real world is sometimes even weirder! :blink:
IIRC Sparrow needs a radar equiped aircraft. Am I right?, where is it?
Wasn't there a proposal to hang Sparrows off a Kaman Seasprite as an anti-FPB weapon? Could it be related to that? It's been said that a Sea Skua is basically a slow Sparrow........
Quote from: Weaver on June 16, 2008, 06:08:20 PM
That would be this:
