avatar_Tophe
Asymmetric readings
Started by Tophe, September 09, 2005, 10:18:45 PM
Jeff BlackOps [adding colours and "Reality" (J-18 topic) to a comparative sketch, port of one aircraft vs. starboard of another to compare] may have invented a whole class of asymmetric aircraft! Inside I am glad to focus on the twin-fuselage Zwilling part...
Below is a port Heinkel He 111Z/5m compared to a Sisko/Toff (Siskel) He 222Z/7m ; read as a whole, in the great BlackOps-way, this provide us with the weird asymmetric ToffOps He 333Z/6m...
If you ask why such asymmetry, there are answers, don't worry. For instance: all the engines were rotating in the same direction (from the begining or because one factory among two had burnt), so the torque was huge and asymmetry provided stability...
As well without twin-fuselages: the comparison between Go 244B & Go 444 could have created a Go 344B... :)  (I have already presented elsewhere the Go 243 between 242 and 244, not realising this is a whole generation process).
From the misread 'view from above' was born a 'Real' machine...
The He333Z code was replaced by He231, I don't know why, the ground crew even telling puzzles like "He-132 code while going away, He-231 coming back, always!". A local clown, walking on hands, denied: "No! 231 going away, 132 coming back!" with approval of an Arabic witness, standing there and hearing us. Mysteries...
While a double-plane usually requires double-power, it may have been different for a single-plane with additional-fuselage.
Above, project HB-29T-2 was a B-29 designed to transport/spray lethal bacteria/viruses: little load but needing to be separated from the crew and technical staff. Safe efficiency...
As the B-29 fuselage was available (with useless glazed nose) in the 1944 production line, it was selected as biological hold, but a single extra-engine was enough to carry all: thus such a 5-engined completely asymmetrical result.
The most funny is the way these micro-organisms would have been efficient: making the enemy crazy!... and as simply drawing it, 60 years later, without physical contact, seems already dangerous for sanity, what a thread!
In the first "Forked Ghosts" book, that I am currently translating in English, were presented with the highest number of engines (left below):
- the Percival P.36, 6-engined Burnelli-like, from a 4-engined design
- a Martin 4-engined cargo with low wing, from a 2-engined design
Now it is easy to:
- present versions with less engines (center below)
- imagine asymmetric 3-engined versions, for fun (right below)...
Another way towards asymmetric twin-boomers is twin-booming asymmetric aircraft, I did it with airplanes (Bv141, Ca.381) but this had yet to be done with flying boats... So here below, the asymmetric Blohm und Voss P.111 becomes the asymmetric twin-boom P.111B ^_^
More solid, seriously... ;)
Coming from a trip to Austria, in a Canadair Regional Jet, I wanted to draw such a T-tail jet, but with 2 tails and dated 1939-45, of course, so aboard I smiled and drew the asymmetric P-38TXF (T-tail + extra fin)...
On computer at home, to draw it more properly, this has become a mix of a P-38JR-3 (for starboard) and a P-38DF (for port)...
Mixing a half P-61 Black Widow with a half GP-61 Black Glider made the P-61S Black Single (or Light Widow):
(from http://www.enter.net/~rocketeer/p61drwng.jpg )
No, seriously: a night fighter needed a free radar nose, all right, and maybe a rear post, so this required a pod for the crew, not the classical fuselage with nose engine/rear tail of a P-51/P-47, all right. And the twin-boom layout was solid, perfect for that, maybe better than the Bv 141 layout. But why 2 engines? No need!
[I consider seriously building this P-61S, in 2007 or 2008... I have a 1/72 Airfix kit available]
I think I should mention here that, up to now, I have posted 62 asymmetric drawings in the topic
http://www.whatifmodelers.com/forum//index...?showtopic=4626 and 27 in the topic http://www.whatifmodelers.com/forum//index...?showtopic=5092 . With the 9 in this topic, that makes 98 new ones added to my Forked Ghosts collection, and I just have to add 2 to get 100, so here they are: Me 322Z as average 321Z + 323Z:
Edit Jun 23rd: I have posted 13 more asymmetric inventions at http://www.whatifmodelers.com/forum//index...showtopic=10863
Edit July 22nd: and more modern: 10 asymmetric double-deltas at http://www.whatifmodelers.com/forum//index...?showtopic=8523
Edit August 27th: and 6 asymmetric derivatives at http://www.whatifmodelers.com/forum//index...showtopic=11771
All of you know pretty well the Martin B-26 Marauder, but the Martin B-33 Super-Marauder is far less known. I have asked Google and two discrepant pictures were got from the Wikipedia encyclopaedia: 2-engines (XB-33) or 4-engines (XB-33A). And the more surprising was the text saying "the XB-33 was a twin-tailed..."
Hey, what a mess!
- 2 OR 4 engines (1 OR 2 per wing)?
- Twin-tail OR twin-fin!?!
Relax: I have the solution, as the XB-33Z:
- 1 engine per wing AND 2 engines per wing
- Twin-tails AND twin-fins
The mystery is "solved"... :wacko:  :D
Let us discard seriousness: I am a what-ifer, yes or no?
So, what-if the XB-33 was turned into the glider GB-33, and the 4-engined XB-33A into the 6-engined XB-33B? From this came the weird B-33Z, immediately mass-produced 1944... But why so many engines as 2 were enough for the XB-33? That leaded to the 2-engined B-33Z-2, with asymmetry still as there was no fuel line for an engine in the short port wing...
As a further demonstration: look how sad would have looked the situation without asymmetry: GB-33Z(s) glider(s) tugged by a TB-33Z, just like a poor US copy of a He 111Z tugging Go 242s... :(  No, US engineers were able to do better, more inventing, more challenging, thus the asymmetric way explained above... :blink:  :wacko:
As well, comparing side by side a C-47 Dakota and a CG-17 glider-derivative is more funny if you imagine this is an asymmetric twin-plane (C-47CG-17). A twin C-47Z and a twin CG-17 are fun too, but without asymmetry, this is rather sad...
Of course, in the sad funless Reality, the basic C-47CG-17 would have been simplified: no need of so many tailplanes and landing gears... :(  even if this C-47G may have been kept asymmetric... :)
QuoteMe 322Z as average 321Z + 323Z:
- Hey you stupid what-ifer, the Me 321Z and 323Z have never existed, how to join them?! :blink:  :wacko:
- Uh... we could join a Me 321 and a Me 323...:
- That cannot work either!
- So the Nazi would loose war :)
- Well, yes. You stupid but not a bad guy.
