avatar_The Rat
Westland Whirlwind
Started by The Rat, September 26, 2005, 03:21:27 PM
Quote from: Weaver on April 01, 2010, 07:00:23 AM
Quote from: sequoiaranger on April 01, 2010, 06:11:13 AM
As far as "fattening" the Whirlwind to put in a turret, one of the salient features of the Whirlwind was the extremely narrow fuselage that kept wind resistance to a minimum. Fatten the fuselage and put in a turret, and, well,...the aerodynamic advantages disappear. You would now have a "Mosquito" with the low power of Peregrine engines instead of Merlins.
Yes, but it'd be funny in a "really bad ideas" kind of way........ :wacko:
Actually, thinking about it, it wouldn't have to be that wide: only as wide as a Defiant, which is still way narrower than a Mosquito...
brewerjerry
Quote from: GTX on April 09, 2009, 03:18:33 PM
Something I just whipped (or should that be whiffed) up:
Hi
   Now this I like,
   Westlands actually proposed a whirlwind with american radial engine, i probably was either wright cyclone 1820 or the pratt & whitney 1830, I havenèt worked out which would have fitted yet, i.e.. size ..weight
   Out of curiosity, which engines are in the profile
      cheers
        Jerry
brewerjerry
Quote from: rickshaw on April 16, 2010, 09:03:57 PM
I've just found out that Special Hobby do a Whirlwind kit in 1/72.  Has anybody made one?  How does it compare to the Airfix one?  Its about 3 times the price. Is it worth it?
Hi
   I have the fighter bomber quite nice and just ordered the latest issue  ..different whirlwinds..off e bay.
    The idea i have is to use the nose cone, remove the 37mm and convert the longer nose back to the PR nose that westlands originally were going to do. It could look nice in PRU colours.
  I was think of putting the nose on the airfix, cheaper than using the special hobby.
   Someone told me that they thought special hobby may issue a 1:48 version.........would be nice if it is true.
    cheers
     Jerry
Quote from: brewerjerry on April 24, 2010, 08:56:13 AM
Jerry,
I can't quite remember - I think I was considering something like the Bristol Taurus or even the more powerful Hercules.
brewerjerry
Hi greg,
           Thanks for the reply, the profile looks good, might use it as a basis to bash an airfix kit into one of them.
      Did you ever try a drawing with merlinXX's on the whirlwind, as per westlands 1941 proposal ?
         Cheers
           Jerry
You could actually do a Whirlwind with late model Mercurys, which had more power and less weight than the Peregrine. It'd have more drag and worse altitude performance, but it'd be good as a ground attack type or a dive-bomber (with airbrakes).
Twin Griffon power!
'There's no subtitute for cubic inches' (quote some US drag racer in the 60s sometime)  ;D
Quote from: PR19_Kit on May 06, 2010, 03:54:52 PM
Twin Griffon power!
Check out page 2 of this topic ;D.
Twin Griffon power!
Go back 15 posts Kit, you'll see what I've read recently.
There you are then, great minds think alike. Even in WHiffWorld.  :lol:
brewerjerry
Quote from: kitnut617 on May 06, 2010, 08:58:34 AM
Now this looks interesting :
http://www.aviationmegastore.com/?shopid=&action=prodinfo&parent_id=&art=93142
Hi
   The nice postperson delivered one yesterday, it has the long nose and the handed propellers.
     It looks good, and by using two airfix kits and the one SH, it will turnout three whirlwinds, more if I can figure out how to 'clone' the long nose'
       Cheers
         Jerry
Quote from: PR19_Kit on May 07, 2010, 03:01:47 PM
I tend to think of it as suffering from the same madness ;D
I suspect I will be burned at the stake for suggesting this.  Has anyone ever considered a single-engined Whirlwind?   :o
