avatar_Mike Wren
Shorts Skyvan and Sherpa
Started by Mike Wren, October 15, 2005, 04:46:22 AM
Quote from: Weaver on July 03, 2009, 01:48:26 AM
Quote from: Weaver on July 01, 2009, 07:33:50 AM
So if one of us (it might not be me) does turn a Budgie into a helicopter, what should be do with the spare wings? What would benefit most, or most entertainingly, from the Hurel Dubois treatment?
In answer to my own question, how about sticking the wings and engines on a Wessex and replacing the original enginer bay with a clamshell nose-doors to make a sort of mini-Bristol Freighter?
Thinking about this some more, if you wanted to do a Helivan as a conventional MTR layout, then a Wessex/S-58 would make a good rotor-donor since it's empty and MTO weights are only a little higher than the Skyvan's. It doesn't help you with engine pods though (except a nice pair of nozzles) nor with a tail boom, since the Helivan would require a high-mounted lollypop-stick-style one.
There's a lot of Wessex kits about, but the radial-engined S-58 would probably be easier to convert to clamshell doors.
Dimensions are tricky since many refences don't make it clear whether they're including rotor heights/spans in their figures or not, but the height of the Wessex/S-58 looks to be at least in the right ballpark to use the Skyvan's wings and struts (you could always change the angle of the latter, of course).
The Wesvan would probably look like a Bristol version of the Twin Pioneer.... ;D
Contrarotors.  A Kamov Ka-25 should work as a donor, numbers are little bit higher but should work well & you won't have to do anything much more than hack off the engines & rotor & slap them on.  The Ka-25 would need a little more work if you wanted a loading ramp.
Well for those not following the GBs, I'm actually doing the egg-beater Helivan now.
However, the main reason for posting here is Another Evil Idea (TM):
How about doing a Skyvan as a tour plane (yes, tour bus might be more appropriate...  :rolleyes:) for this lot, in the mould of a budget-price (budgie-price?) Ed-Force One:
http://www.budgie.uk.com/index.html
http://en.wikipedia.org/wiki/Budgie_(band)
A few album covers for inspiration: http://pixhost.info/pictures/1203895
There is/was even a spin-off group (don't quite understand what went on) called "6-Ton Budgie", which was one of the band's original names before they shortened it.
Given the band's origin, their limited success, their quirky humour and the Skyvan's short range and small size, "WORLD TOUR OF WALES" might be an appropriate slogan....  ;D
The band have whiff-form too. When Roger Dean did this album cover for them, he made a model of it - got a pic of  it somewhere:
The Skyvan features as the main aircraft in the recent animated movie "Rio".  The bird smugglers use one for their nefarious deeds.
DarrenP
#79
I remember seeing Skyvans and 330's and 360's as a kid flying from Sydneham being tested then the Tucano's appeared.
Always liked the C-23 and was disappointed the RAF never got them.
couple of What If's for the Flying Bread van
Ormo (a Belfast bakery/bread Maker)
Air Rhodesia
RAF Middle East AF
RAF Far East AF
RAF Germany
Army Air Corps
Belizeian defence force Transport/Maritime patrol
Jamacian Airforce Transport/Maritime Patrol
Falkland Islands Government Transport/maritime patrol
British Antarctic survey
Maltese Airforce Maritime Patrol
SD330/C23A
Air Rhodesia
RAF Germany
RAF VIP
Royal Airforce Middle East
Royal Navy Heron Flight
Irish Airforce Transport
Irish Airforce Maritime Patrol
SOAF Transport/Maritime Patrol
Short 360
RAF Germany
RAF VIP
RAF Queens Flight
Martin H
#80
well the RAF mid east 6 ton budgie might looks a little like this
heres a few others from various shows
This one is from our own RCB
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Quote from: The Rat on April 27, 2008, 02:22:26 PM
I'm half tempted to paint one as if was made out of wooden planks, paying homage to the old joke "Is that a plane or the box it came in?"
I can remember being told by a Jetstream pilot that the Skyvan parked  beside him was a recycled Jetstream box.....but at least he did add  "......and it shows the value of recycling....."
Aircav
#83
Her's the sketches I did for the Blue Eagles Skyvan, just ignore the Olympic decal placement on the instruction sheet.
The second drawing shows the placement for the ARMY and serial legends, the numbers that are circled are the rivet lines on the model.
All the best
Steve
ps, the drawings were done in 2005.  ;) ;D
Sir Sydney Camm
Vertical Airscrew SIG Leader
All this Skyvan activity reminds me I've had a part built one for at least 15 yrs! I should DO something with it......
How about kitbashing one with a Rotodyne?
Aircav
Quote from: PR19_Kit on June 30, 2014, 06:51:33 AM
Theres always this.   ;D
Sir Sydney Camm
MAD
Yeah have to agree a 'tactical' gunship Sherpa with a 20mm M61 and 7.62mm rotary gun, FLIR turret under its nose, and a hardpoint under each wing for a couple of Hellfire ASM's  sounds like a practical and workable concept. It's STOL/rough field capability allowing it to support COIN ops.
Also a COIN airborne Command, Control and Communications spcialised variant of the Sherpa would be a good and practical application, with antennas, data link and Satcom bulges on its upper fuselage!!
M.A.D
I've been trying to purchase one of those Sherpa models for sometime on EvilBay without much success, Kitnut.  They go for IMO silly prices nowadays.   I'm starting to think it might be easier to purchase one of those evil "Kiln dried, Executive wooden desktop" models from the Philippines...   :banghead:
Quote from: rickshaw on July 13, 2014, 05:29:20 PM
... or just buy a block of nicely kiln-dried wood and start cutting.  ;D
Quote from: joncarrfarrelly on July 13, 2014, 06:35:01 PM
Got to buy a back porch and a rocking chair first, Jon.  ;)
