avatar_Damian2
My 1/48 F-8 and A-7
Started by Damian2, January 21, 2006, 04:01:23 PM
K5054NZ
Riot gas? Won't work too well on the aircraft of the Greenpeace Air Arm  :ar: !
Whose airforce is this? Not the Kiwi one is it? I really like the look of those LGBs, but the chem containers look awesome. Napalm's good for anything (POTENTIAL OFFENCE ALERT!!!) , but the Mavericks are really  B) .
Sorry I'm not too helpful, but each of those looks good - well, the Mavs and the LGBs, and the Korean iron bombs. Perhaps Mavs inboard, LGBs outboard?
Damian2
I wonder if I couild fit an out board pylon on each wing? That'll give me some more space to load bombs! Besides the Kiwi's won't be using the wing folds because these are land based aircraft ;)
elmayerle
I'd imagine that if you use the pylon spacing of the A-7, even with the greater sweep of the F-8's wing, you should be able to get at least one more pylon on each side.
--Jane Wagner and Lily Tomlin
Damian2
QuoteI'd imagine that if you use the pylon spacing of the A-7, even with the greater sweep of the F-8's wing, you should be able to get at least one more pylon on each side.
Ooooh F/A-18 gasbags and slant two loaded Mavs here we come!!!
K5054NZ
Hehehe, I like! :wub:  :wub: Mavs.....mmm......
