Twin-Stang
Started by wolfik, February 23, 2006, 09:24:38 AM
wolfik
hi all :cheers:
something new from my bench....
1/48 monogram mustang(s) and a 1/32 F4 Phantom  center fuel tank from a revell kit.
the work is in the beginning and photos will follow  -_-
wolfik
#1
this is the second version of my idea...with a third engine in the pusher proposal.
the underwing tank is showed.it looks something better and sleekly(rakish?)
and the front wheels are added...
wolfik
#2
the cockpit must be filled.taped with tamyias product and ready for filling...the easiest way...resin :blink:
wolfik
filled with resin...
wolfik
wolfik
and...sanded
thats for today  B)
Yowzers...those are sweet ! I like the second one better. I love the shape of that center section. Not a big fan of the third engine, tho. Which one are you building ? The first one ?
What are you doing with the wing tanks ? Want to trade them for something ? I need a pair for a 48th scale Avro Arrow.
If there is not enough room for a normally large center propeller, a solution would be a double counter-rotating coaxial propeller, no? Big enough thrust with a reduced diameter.
^_^
Kerist Wolfic, that's looking great. Hell of a way to fill the cockpit hole.
K5054NZ
Peter, great to see you back! I sincerely hope you're doing pic 1, it looks like a dream! I want one! :wub:  :wub:
If ever you sell #1 and #2, I may buy both... Even at 1/48, dear... :wub:  :wub:
Love it Wolfik! The second one is my favorite too! I kinda like that pusher engine...very unique!
gooberliberation
If there's not enough ground clearance for the middle engine, perhaps put a turbojet? Itd match all those mixed-propulsion planes in the late 40s
Allan
Wolfie,
Go go go with the pusher!
This model looks like a winner all the way.
Allan in Canberra
datguy
I must admit, I like version #1.
I can't see that the third engine would add much to the design unless it were a turbojet.  The center pod could look like a Vampire then, and you'd get a bigger speed advantage.  Long range cruise on the props, and short bursts of high speed from the jet.  It would need the horizontal stab/elevator up high on the tail, which always looked good on the Sea Vixen.  The nose could get a good heavy armament reminiscent of the P-38, perhaps 4 20mms and a 37mm.
Remember, too, that the P-82 was a MUCH larger airframe based on the Mustang aerodynamic profile, so this is a truly unique interpretation
DG
